Re: What's on your bench right now? [1/43]
Postby BARC 1 » Wed Dec 26, 2018 8:45 am
The Rally was a good event. I was a little surprised how well my Volvo did. That was a pretty heavy car, but it seemed to like the track.
The cars I am sending will be new to you but they have logged many Kleskun Hill laps. A Porsche 906 and a Mercedes CLK touring car. Not sure what the third entry will be. Perhaps a Ferrari P 4
Postby pfuetze » Sat Dec 29, 2018 12:48 pm
sounds like some great cars are heading in my direction ...
in the meantime i got a package from Norway:
Postby Rastas » Sat Dec 29, 2018 5:46 pm
Rastas
Postby Rastas » Sat Dec 29, 2018 5:56 pm
IMG_20181228_180247.jpgAfter 15years there up an running again my brother and I went to the track and gave them a run I'm still walking around with a smile on my face .my next bold will be a Willy's scratch built wire and brass chassis carnt wait to get back to red racers slot car track !!!!!
Rastas
Postby Rastas » Sat Dec 29, 2018 7:22 pm
[attachment=1]IMG_20181229_011637.jpg[/attachment]t
Rastas
Postby walker » Sat Dec 29, 2018 8:19 pm
Are you sure you are in the right forum ?
Here we talk about 1/43. What you show is either 32nd or even 24th scale.
Example - a C-Can Mura as you showed on your last photo never will be usable in any 43rd scale car.
There are forums for 24th scale as well as 32nd.
Regards,
Roland
walker
Postby Rastas » Sat Dec 29, 2018 10:22 pm
OK sorry about that .
Rastas
Postby pfuetze » Sun Dec 30, 2018 3:44 pm
these are better! now which inserts to use?
Postby LloydL » Mon Dec 31, 2018 4:04 pm
The inserts in the bottom photo look good Peter!
Regards, Lloyd.
LloydL
Postby pfuetze » Wed Jan 09, 2019 2:54 am
made a small jig for measuring the wheel base correctly.
6mm aluminium pipe and 8by8mm styrene material. 2 holes for the axles - works like a charm - at least on the 356 :-)
working on the new chassis for the vac-formed Mini JCW - should be ready for the ProNoMag.
K&D were already glued with CA glue to the RD rims, but the polished surface did not let the glue stick. used sand paper 150 grit and made some scratches on the surface - should work better now, hopefully.
Postby taskak » Thu Jan 10, 2019 3:18 am
taskak
Postby taskak » Sun Jan 13, 2019 10:44 am
taskak
Postby pfuetze » Sun Jan 13, 2019 1:37 pm
i really like what i am seeing, Aki!
the Veyron looks great!
Postby pfuetze » Fri Jan 18, 2019 6:42 am
started with the chassis for the 356
1.5mm polystyrene sheet material ...
Postby taskak » Sat Jan 19, 2019 11:47 am
taskak
