Home Racing World • View topic - Anyone for a 1/43 Monte Carlo Rally proxy in 2014?
Re: Anyone for a 1/43 Monte Carlo Rally proxy in 2014?
Postby LloydL » Thu Aug 15, 2013 3:56 pm
LloydL
Postby LloydL » Thu Aug 15, 2013 5:50 pm
I play Petanque as well Roland! lol
Regards, Lloyd
PS, Thanks Broman62, I will be posting some You tube suggestions to help understand the Monte Carlo Rally.
LloydL
Postby transam6870 » Thu Aug 15, 2013 6:18 pm
I'm in awesome track btw
transam6870
Postby LloydL » Fri Aug 16, 2013 4:29 pm
Thanks Mickey.
Regards, Lloyd
LloydL
Postby pfuetze » Fri Aug 23, 2013 7:01 am
Postby Datto » Fri Aug 23, 2013 7:15 am
Datto
Postby masmojo » Fri Aug 23, 2013 10:06 am
masmojo
Postby LloydL » Fri Aug 23, 2013 10:17 am
LloydL
Postby pfuetze » Fri Aug 23, 2013 12:11 pm
minimum front width inside the body is for sure an issue! will check the minimum possible width of the actual construction. it´s only pivoting, no additional front/aft movement.
front and rear movement, too??? or only left/right tilting?
Marc´s mounting post can provide some nice movement for sure.
body weight is not the issue, i think, available springs are for sure the thing thats missing, due to size. maybe some springs from an H0 car from those strange pickup shoes?
Postby LloydL » Fri Aug 23, 2013 12:33 pm
If you look down on a model car wheel that is being steered, the wheel moves through an arc which, in effect, moves the wheel forwards and backwards, This does not notice in an open wheeler, but can be limiting in a small touring/sedan car.
Regards, Lloyd
LloydL
Re: AW: Anyone for a 1/43 Monte Carlo Rally proxy in 2014?
Postby pfuetze » Fri Aug 23, 2013 1:17 pm
It's the offset from the pivot to the rim that is creating this. I tried to keep this as short as possible, but a liile is necessary. On real cars this is way less than on modell cars.
Sorry for the o.t.
Looking forward to this race.
Postby masmojo » Fri Aug 23, 2013 2:34 pm
Also when you add steering the wheels and wheel carriers need to sit a little further inboard so they don't rub! Especially if there is going to be some body roll introduced into the equasion!
masmojo
