Little Monte rally track revisited.
Re: Little Monte rally track revisited.
Postby JimD » Mon Feb 25, 2013 3:32 pm
Lloyd,
Very cool! Is that 1/2" MDF or something else? Looks like you really get a lot of bend at the transitions? Are you back cutting it in those spots or maybe not if it is something softer than MDF?
I like it! We have jokingly said we should incorporate a hill climb into the next project. I'm sure someday it will happen.
Thanks for posting!
Jim
JimD
Postby LloydL » Mon Feb 25, 2013 4:11 pm
Thanks guys!
Jim, the first section I made, the white zigzag hillclimb, is from 1 piece of 12mm (1/2" I think) MDF, 4' x 2'. I routed it, then cut it out with a jigsaw, and then just carefully lifted the top section and mounted it onto a framework. It bent into shape quite easily with no damge in the transition areas.
There are no cutouts underneath.
The rest of the track is 9mm MDF and, except in 2 areas, there are again no cutouts underneath. In the 2 places that I did cut underneath, the bend is a bit too sharp, so the cuts were not actually needed.
I hope this makes some sense.
Regards, Lloyd.
LloydL
Postby JimD » Mon Feb 25, 2013 4:15 pm
Ya, thanks! Looks like a blast! I know we are going to have to do one here in the future!
Jim
JimD
