Home Racing World • View topic - weight
weight
weight
Postby walker » Sun Oct 02, 2016 3:03 pm
Dan, could you please check how much your and Akis proxy cars weigh, and what motors are installed ?
Thank you,
Roland
walker
Re: weight
Postby taskak » Mon Oct 03, 2016 3:19 am
Hi Roland, my Porsche is Carrera GO with original motor and gears,
Nissan got SXC chassis with SCX original motor and gears.
Dan can measure the weights.
taskak
Re: weight
Postby walker » Mon Oct 03, 2016 3:40 am
Thank you, Aki.
Roland
I forgot - yet another question :
What Motor is in the Mustang ? GO! / SCX - size or the smaller N-20 ?
walker
Re: weight
Postby BARC 1 » Mon Oct 03, 2016 11:27 am
Re: weight
Postby pfuetze » Mon Oct 03, 2016 11:47 am
Are you sending in a car, Roland?
Re: weight
Postby walker » Mon Oct 03, 2016 12:12 pm
walker
Re: weight
Postby taskak » Mon Oct 03, 2016 1:55 pm
Roland, Mustang motor is N20;
FF-N20PA-10190 3V-6V 12500rpm-23000rpm High Speed HM Carbon Brush Motor
Costs about 1 euro each.
taskak
Re: weight
Postby Dodgefarmer » Mon Oct 03, 2016 2:01 pm
Dodgefarmer
Re: weight
Postby BARC 1 » Tue Oct 04, 2016 9:40 am
Yes it is an interesting observation that this 40-45 gram weight seems to be the weight that works. When your Mazda shows up I will let you know, and thanks for joining
Re: weight
Postby walker » Wed Oct 05, 2016 4:11 am
walker
Re: weight
Postby pfuetze » Wed Oct 05, 2016 4:30 am
you can bet on that one, Roland!
i did not weight them, sorry.
i´m looking forward to the efforts that Dan is putting those data!
Re: weight
Postby BARC 1 » Wed Oct 05, 2016 8:22 am
Well Peters cars arrived yesterday.
The Porsche 956 is 40 grams and the Mini is 30 grams. Both with really nice clean chassis work.
I am doing up pictures and a run down on each car. I will post this once I start qualifying the cars.
Re: weight
Postby walker » Wed Oct 05, 2016 10:10 am
Ten grams difference - a matter of vacforming, I think. And the overall dimensions of course, too.
Roland
walker
Re: weight
Postby BARC 1 » Wed Oct 05, 2016 12:19 pm
Once the cars arrive they go through inspection. The design of the mini with the open motor and its low track clearance, benefits from some inherent magnetic traction from the motor magnets. I measure this tractive effort as 9 grams. No magnets have been added to this chassis, and on a wooden track this traction would not be there.
Interesting that with the magnetraction the weight of the car climbs to 39 grams.
Lloyd had brought this to my attention at the very beginning that cars built with HO open motors would have some magnetraction advantage. This is noted, but will not keep the mini from participating in the race, even though Peter graciously suggested it be pulled for the contest. It is a fun run after all, and the fun is in participating not sitting in the garage, after its long journey here.
The amount of magnetic traction is light and the car can still lose the back end, and it gives excellent feedback to the driver, but it does have an advantage over the other cars entered, ie it has 9 grams of virtual weight because of the magnet, but that mass does not need to be handled by the chassis.
Like LeMans different classes of cars can still race on the track, and if I had more cars entered that fell into this category they would be classed differently and race against each other.
The stewards have ruled no foul, but the final results will indicate this inherent advantage.
Re: weight
Postby pfuetze » Wed Oct 05, 2016 2:57 pm
most of the weight difference is coming from the motor i think, plus a small part from the body.
the Kyosho are excellent, also regarding weight.
But the DSlot motor has significant more weight than the Box motor.
The Mini has an inlet with a driver figure, the 962 comes with smoked windows and nearly no space for the driver figure due to the motor. Even if the PDKD motorpod chassis places the stock motor further behind, still not really enough space there.
