Home Racing World • View topic - Ford vs Porsche Proxy Round 11 - Penguin Point
Here we go! Round #2 in what started last year as a proxy duel between both builders and marques.
Postby kidvoltage » Mon Jul 09, 2018 2:11 pm
A very large box of car has arrived. I'll get it opened, give them all a test run and round up the gang.
More as it develops.
Thanks.
kidvoltage
Re: Ford vs Porsche Proxy Round 11 - Penguin Point
Postby Mitch58 » Mon Jul 09, 2018 3:35 pm
You know where to find me.
Mitch58
Postby FC47 » Mon Jul 09, 2018 3:47 pm
Thanks for hosting us guys!!
FC47
Postby Audi1 » Mon Jul 09, 2018 6:46 pm
Glad they arrived safely, Monte. Looking forward to the race at Penguin Point!
Postby kidvoltage » Fri Jul 13, 2018 10:32 am
I've unboxed all the cars, most look great. The BARC car is still looking pretty rough - and it's missing a screw. I'm sure I've got one here somewhere...
And as for racing, temperatures in Oregon this week will be in the 90's. Add about another 15 degrees in the garage. We'll try to get the race in as soon as I can raise a crowd and the heat drops a bit.
kidvoltage
Postby Audi1 » Fri Jul 13, 2018 11:29 am
Yup, it's in the 90's where my track is located right now - too hot for both the cars and the drivers.
Postby Mitch58 » Fri Jul 13, 2018 3:32 pm
But just think of all that grip.
Mitch58
Postby docdoom » Fri Jul 13, 2018 7:14 pm
docdoom
Postby arroldn » Fri Jul 13, 2018 9:57 pm
Where isn't it hot???? 95-96 heat index 105. Wow cools off Sunday. Highs in the mid to upper 80s. That's a break I'll take.
arroldn
Postby CrockettNZ » Sat Jul 14, 2018 12:11 am
CrockettNZ
Postby kidvoltage » Thu Jul 19, 2018 8:23 am
The weather finally took a day off and temps crested in the reasonable 80's. We gathered a group of racers and gave the cars a good run. Some runs were gooder than others.
We had one pre-race issue and one race issue. The BARC car #19 had loose pieces of most everything floating around inside. Goose took the car apart and basically put it back together and made it reasonably raceable - it was still the major handful. The Brumos car #111 decided to take a heat off. It just quit running. I took it apart and couldn't see anything wrong. I set it back on the track sans body and it ran. Put the body back on and it still ran, back in the race! WTF! Slot cars...
So our merry band of racers was Paul, Dave, Al, Rico and Goose sharing the driving duties while Mitch and I attended the corners with the others helping between driver stints and my lovely wife Victoria handling the excel spreadsheet and keeping Kleo the cat at bay.
I ran a qualifying set for each car and there were some serious bullets being fired. This was easily the fastest set of cars we've ever proxied here. Multiple cars were running sub-seven second laps. We don't see that here.
Here is the qualifying times as driven by myself in the center lane with power at a romping 10 volts:
So comments...
If your car was in the mid-7's and higher it may not be competitive in this field for this track.
If your car was in the low 7's, it was very fast.
if your car broke the 7-second barrier I was probably checking for traction magnets! ;-) :scared-eek:
I was amazed at how many wonderful cars there were in this field. Almost every car that touched the track felt like a track hugging rocket.
Finally it was time to stop talking and start chalking. Some cars race better than they qualify and some worse. We were about to find out which.
I should point out that during the race banter the most interesting point of conversation became the debate over how many heats there are in a 39 car race. Some of you reading at home may already know the answer, don't spoil it for the rest. We eventually arrived at an answer many of us could agree on. :angry-tappingfoot:
The Penguin Point course is a tight. twisty layout with a 15 foot straight to tie all those corners together. This is a track for the handlers more than the speed demons. Fast just makes you an unguided missile. Handling will make you a winner. That reminds me... when Porsche first entered competition in any form they went to a hill climb. At that event their car went up the hill so fast for it's class the scorers refused the time and made them go back and run again - something must be wrong. When they produced about the same time the second trip through the scorers were left with no other option but to accept the time. Thus began the legend of the little german cars whose best skill was maintaining a rapid rate over uneven, twisting terrain.
But would that be enough to take on the mighty Fords?
Maybe not every day. Maybe not every day on this track. But for one day, this day, Porsche was good enough.
Yes, it's a Porsche Sweep!
One more round to go.
kidvoltage
Postby alexis in greece » Thu Jul 19, 2018 9:41 am
Thanks Monte for the qualy and feedback but are you sure there is no mistake?My car (in previous races finished from 10th to 20th) 4th and yours 20th? Unbelievable
alexis in greece
Postby F1Fan » Thu Jul 19, 2018 9:48 am
YEAH YEBO!!
Lez, is this a first ever TQ for you? Well done either way!
Thanks Monte for the run at Penguin Point.
F1Fan
Postby kidvoltage » Thu Jul 19, 2018 9:55 am
Congrats Alexis. The penguins don't lie. Horses for courses.
kidvoltage
Postby arroldn » Thu Jul 19, 2018 10:10 am
Monte,
Thanks for hosting and the crew that you had to run this round. Glad to see my little Porsche finished ahead of some of the top proxy builds at Penguin Point.
Congratulations to the Porsche Class of cars that finished 1,2,3.
Great series. 8-)
arroldn
Return to Ford-Porsche Wars Proxy 2017
