Ford-Porsche Wars - Round #2 - Cornerstone Raceway
Here we go! Round #2 in what started last year as a proxy duel between both builders and marques.
Re: Ford-Porsche Wars - Round #2 - Cornerstone Raceway
Postby JT Previa » Sat Oct 28, 2017 7:29 am
The soundtrack is even era specific: The Doors on now.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 7:34 am
First heat!
JT Previa
Postby JT Previa » Sat Oct 28, 2017 7:45 am
The narrow 19 Porsche is fun to drive, but requires respect going into corners. Hops a bit.
60 needs a good bit of controller braking
All the cars in this group
JT Previa
Postby JT Previa » Sat Oct 28, 2017 7:52 am
Porsche 1 shudders under acceleration and struggles for traction there and in corners. But, the car has power and needs strong braking before corners. I like the sound of this car
JT Previa
Postby JT Previa » Sat Oct 28, 2017 7:57 am
Under acceleration, the 60 GT40 nose dances around like a gasser on the 1/4 mile. Settles into corners and can be driven out. Fun and challenging to drive.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:05 am
The 30 GT was smooth, but drove right though one corner three times: a very light nose creating smooth front end deslots - slot car understeer! Geared for top end, the car gathered speed regally, allowing acceleration from deep in the corner.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:09 am
Tires cleaned:
Brain has a handful of the next heat!
JT Previa
Postby kidvoltage » Sat Oct 28, 2017 8:12 am
Badges and everything, ya'll got it going on. Have a fun day.
kidvoltage
Postby JT Previa » Sat Oct 28, 2017 8:23 am
#20 GT. Time warp acceleration, reasonable in corners, but would fishtail to deslot. Narrower body than many other cars.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:33 am
74 mirage has sedate acceleration, tires tend to glaze. Fishtails then tips out when tire grabs.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:49 am
No 32 917, Porsche in front as God intended it! This leadsled drives like a Lionel locomotive. No offs, won that heat.
Point and shoot, instantaneous response, red 6 GT 40 was thrill to drive.
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:50 am
Heat results:
JT Previa
Postby JT Previa » Sat Oct 28, 2017 8:56 am
Next heat!
JT Previa
Postby JT Previa » Sat Oct 28, 2017 9:04 am
#47, Porsche 908-3 had more motor than needed, chatters and steps out on acceleration, despite sensitivity turned up. Typical sign of anglewinder flex. The short wheelbase / guide to rear axle length don't help. I do love 908-3s!
JT Previa
Postby JT Previa » Sat Oct 28, 2017 9:10 am
Steady and medium speed. Extra deep guide seemed to drag, some occasional hesitation.
JT Previa
Return to Ford-Porsche Wars Proxy 2017
