Tires for this?
Tires for this?
Postby litng1 » Mon Jul 22, 2013 12:39 pm
What tires can I put on this chassis.Um unsure.
litng1 from Bardstown ky.
litng1
Re: Tires for this?
Postby munter » Mon Jul 22, 2013 1:47 pm
What diameter are the rims....on the centre section?
Might consider foam tires because of the rim type or some of Paul Gages Urethanes are for the rim with the raised lip at the edges.
Re: Tires for this?
Postby nhdungeonracer » Mon Jul 22, 2013 1:56 pm
Is that a Revell chassis?
Re: Tires for this?
Postby TsgtRet » Mon Jul 22, 2013 2:07 pm
Check with Tiny Motors, he does repop tires for Strom, Eldon, Revell etc. He also does Strom and Eldon replacement body parts and some cool repop bodies.
http://www.tinymotors.net/
Re: Tires for this?
Postby DHansen » Mon Jul 22, 2013 5:28 pm
E.J.'s Hobbies all so make tires that will fit them pt.# EJS16 GP tires. There real soft rubber, not silicone. The more you use them the better they grip. They measure 13/16 Dia. X 5/16 wide. Here is his link. http://www.ejshobbies.com/index.htm
DHansen
Re: Tires for this?
Postby litng1 » Mon Jul 22, 2013 5:48 pm
Yes a revell chassis.Thanks guys
litng1
Re: Tires for this?
Postby litng1 » Mon Jul 22, 2013 5:49 pm
Great info guys.
litng1
Re: Tires for this?
Postby RichD » Tue Jul 23, 2013 7:03 am
Super Tires has tires that fit a regular couble flange wheel, silicone and urethane versions are available in diameters from 0.750 to 0.840 inches.
Re: Tires for this?
Postby litng1 » Tue Jul 23, 2013 12:45 pm
Found tires.Now how about a drop in motor and pinion for it?
litng1
Re: Tires for this?
Postby litng1 » Fri Jul 26, 2013 10:02 pm
Looking for a motor and pinion.Any help?
litng1
Re: Tires for this?
Postby Smilin Ray » Sat Jul 27, 2013 5:59 pm
I have a couple different tires for Revell in urethane.
The motor in that Revell is ususally a grey/silver old style can. If you're still looking for one I'll check. Let me know.
Smilin Ray
Re: Tires for this?
Postby Smilin Ray » Sun Jul 28, 2013 9:17 am
I have one of these motors w/pinion, no wires. It measures 1.4". I've also seen a Revell chassis like this one that has a similar can but it measures a bit shorter. If your chassis needs the 1.4" motor message me.
Regards;
Smilin Ray
Re: Tires for this?
Postby DHansen » Sun Jul 28, 2013 9:34 am
E.J.'s all so has motors and pinons. http://www.ejshobbies.com/index.htm
DHansen
Re: Tires for this?
Postby litng1 » Sun Jul 28, 2013 4:58 pm
Thanks again for the help guys
litng1
Re: Tires for this?
litng1
