Home Racing World • View topic - Re: Anglewinder Jagermeister #17
Postby Florida_Slotter » Wed Sep 19, 2012 2:59 pm
sascws90,
I do hope you meant .035 rather then .35 spacer.
Postby RichD » Thu Sep 20, 2012 6:53 am
With an anglewinder if you are using a straight pinion gear and you can't move the motor the only way to get the correct gear lash is to shim the spur gear. Slot.it has spur gears with the boss on the inside or the outside.
Postby nhdungeonracer » Thu Sep 20, 2012 9:55 am
Postby nhdungeonracer » Thu Sep 20, 2012 10:34 am
Ha! Talk about good timing! I just got a call from the distributor that the pinion/press tools are back in! :clap:
:dance: :dance: :dance:
Postby nhdungeonracer » Thu Sep 20, 2012 1:39 pm
Nothing was said about a price change, so I'd expect the price to stay at $59.99 retail...
