by JULES » Thu Apr 11, 2013 2:23 pm
It depends on the grade on the original magnet but ,say assuming it is NdFeb, if you stacked an N35 grade on top of another N35 grade you would find the coercive force would increase by a factor of 1.2 and the intrinsic coercive force might be > 1.6, reading as KOe or KA/m respectively. The maximum energy pull would be increased in the 'all around' field rather than directional, ie not just downwards.
Stacking mags one of top of other is not an accurate way of 'tuning' the force. Better to use simple steel shims. One mag on top of the other is very hit and miss.
Tomorrow, if you like, we can move onto the relationship of magnet grades and the coercive force expressed in the KA/m vs. the KJm3 maximum energy likely properties in respect of atmospheric and TWdegsC environments and whether if you live in the Southern States you should consider a switch from Neodymium to Samarium-Cobalt magnets for their superior ability not to be affected by air temperature.
Jules
