SCC ?
Re: SCC ?
Postby HomeRacingWorld » Fri Mar 29, 2013 8:56 am
This car sir? Just trying to help.
Re: SCC ?
Postby HomeRacingWorld » Fri Mar 29, 2013 9:23 am
15x11 sir.
Re: SCC ?
Postby HomeRacingWorld » Fri Mar 29, 2013 9:45 am
You are welcome.
Answers: .50
Correct Answers: $29.95 + tax, license, processing, shipping and handling :)
But since you have over 100 posts, you get a 100% discount.
Re: SCC ?
Postby nhdungeonracer » Fri Mar 29, 2013 10:42 am
I was gonna say...
If you're going to start charging for your answers, I'm going to stop asking questions.... :lol:
Re: SCC ?
Postby BRS Hobbies » Fri Mar 29, 2013 11:42 am
Harry,
I like the sound of a 100% discount.
What's my discount since I only have 41 posts on your new forum? If it isn't very good, then I really need to up my game posting here.
Best regards,
Brian
BRS Hobbies
Re: SCC ?
Postby HomeRacingWorld » Fri Mar 29, 2013 12:43 pm
Well, of course we need to see you more around here Brian :)
You have a free access as well :)
Re: SCC ?
Postby TsgtRet » Fri Mar 29, 2013 1:18 pm
Geez Harry, you are such a soft touch, good thing you have The General around to keep an eye on you or you'd give away the farm!
Re: SCC ?
Postby raceeng18 » Fri Mar 29, 2013 2:06 pm
If you want to upgrade the axle and gears, Slot.it 19mm spur with the 6.5mm pinion is what I have on my 512's.
Joe F.
raceeng18
Re: SCC ?
Postby nhdungeonracer » Fri Mar 29, 2013 4:41 pm
Yes, if it's inline, you'll need the 5.5mm pinion.
Also, check and see how the motor shaft is in relation to the rear axle. If the motor shaft is lower than the axle, you'll need the white offset Slot.It gears. If they are lined up, then you can use the standard colored gears.
I mention this because my Flyslot Porsche 997 motor was lower than the rear axle. I'm guessing your Ferrari could be also...
Re: SCC ?
Postby svanaken » Fri Mar 29, 2013 5:08 pm
If you are concerned about fidelity to the real car, then you may want to go with BWA double dish wheels and the appropriate resin inserts. As nice as the SCC wheels are, they are not prototypical for the 512.
Scott
svanaken
