Home Racing World • View topic - racer motor switch
racer motor switch
racer motor switch
Postby 351c » Sun Sep 01, 2019 10:20 pm
Hey guys what motors are you using to replace the yellow motor
that comes in the Racer Capri? I have a Carrera track running 12 volts,
These motors are just a little on the hotside. any ideas?
351c
Re: racer motor switch
Postby mikeinclover » Sun Sep 01, 2019 10:51 pm
If you want to stay with te long can style motor try a Sideways Baby Raptor or the Jaws motor. We use the Piranha in them but that is a small can motor.
Mike
mikeinclover
Postby Wobble » Mon Sep 02, 2019 1:05 am
Ninco NC2 or 5 or FLY FK-180 but will hang out the bottom of the pod about 1mm and will also add weight to the tail end. One of my cobber's has a FK-180 in his Capri so they must fit.
Wobble
Postby RichD » Mon Sep 02, 2019 7:15 am
You could put a diode or two in series with the original motor. One or two 1-2 amp diodes should do the trick, each on will reduce the voltage by 0.7 volts. The diodes must be pointed in the right direction.
Postby War Eagle River » Mon Sep 02, 2019 8:30 am
War Eagle River
Postby Kevan » Mon Sep 02, 2019 4:12 pm
Better still fit a SlotIt sidewinder pod then you have access to plenty of choice and sidewinders are MUCH smoother.
Kevan
Postby buspor63 » Tue Sep 03, 2019 1:13 am
buspor63
