Home Racing World • View topic - Drivers heads, where to find?
Postby williamg » Fri Mar 01, 2019 10:30 am
I'm fixing up some older Strombecker cars and need some heads. All I seem to be able to find are 10-15 dollars EACH
These are just runners, not some museum piece. Accuracy is not needed.
Hell I'll use a ball of glue before paying that.
Anyone know of a cheap source? I'm not worried about high quality parts.
williamg
Re: Drivers heads, where to find?
Postby viejoronnie » Fri Mar 01, 2019 11:49 am
The absolute cheapest method I have used is grab some Dollar store fake Lego figures; removing/painting helmets on them. Perhaps only one step up from a ball of glue or pink plastic bead head with painted on full face helmet (I've used that too). ;)
Ejshobbies.com had drivers for only $3.50 each, they might have a minimum order amount.
bigdonkeyresins has 1/24-25 drivers with multiple heads for $6, but they might know who has 1/32 resin heads.
viejoronnie
Postby mattb » Fri Mar 01, 2019 1:24 pm
Go to Hobbly Lobby and buy some Alumilite casting resin and High Strength mold rubber. Learn to make parts like this for near nothing.
Postby glasshorsevh » Fri Mar 01, 2019 1:31 pm
glasshorsevh
Postby williamg » Fri Mar 01, 2019 2:59 pm
williamg
Postby mattb » Fri Mar 01, 2019 4:48 pm
The guy at Dart sure has a nice track. His personal guidelines for building a track are on his site and they are right on. I think that it is probably easier to rout a solid piece of MDF and then if you want elevation, you can cut and raise parts of your road. He has used the model RR method of building a roadway on an open grid. That is a little more involved and a new builder should probably be realistic about his skills and start with the easiest method, working with a flat table top.
I'm sure he will make nice parts for you.
Postby vonsirius » Fri Mar 01, 2019 11:00 pm
Take a look at "Inmense miniatures"
Great helmets/heads there.
http://immenseminiatures.com/Immense_Mi ... res_1.html
vonsirius
