Home Racing World • View topic - cheap power supply
cheap power supply
cheap power supply
Postby mattb » Sat Feb 23, 2019 8:21 am
https://www.banggood.com/Wholesale-12V- ... rehouse=CN
This is what I use and it will power 4 of any kind of car with amperage to spare. This ad came thru my email this morning. Great deal at $17.99
Re: cheap power supply
Postby TuscoTodd » Sat Feb 23, 2019 9:04 am
30 amps? I would say!
(can't knock the price either!)
Thanks for the link!
:D
Postby Kemtronracer » Sat Feb 23, 2019 2:26 pm
I've used one of those supplies for years. They work great!!
Kemtronracer
Postby frank9129 » Sat Feb 23, 2019 7:14 pm
Can the voltage be adjusted?
I'm going to order one just in case.
Thanks a bunch.
frank9129
Postby chappyman66 » Sun Feb 24, 2019 8:05 am
If the supply can't be adjusted, you just build the adjustment at the driver's station.
I have half a mind to get one just as a cheap back up..
Postby RichD » Sun Feb 24, 2019 8:27 am
The voltage is not adjustable, this article includes ways to add that feature: https://drive.google.com/file/d/1r_mey6 ... sp=sharing
Postby chappyman66 » Sun Feb 24, 2019 9:55 am
Or look for the DIY Adjustable Power thread on here.... ;)
Postby hksk25 » Sun Feb 24, 2019 1:15 pm
If you scroll down page there is a 0-48 volts 10 amp adjustable for $38.99
Harry
hksk25
Postby GoldGuy » Sun Feb 24, 2019 2:57 pm
I've got the exact same power supply and yes, it IS adjustable. You just turn the orange fitting on the pot, found at the left. Mine goes from 9 to 14 volts. Fine tuning the maximum voltage (RPM) to the track and cars makes a huge difference in the fun factor.
GoldGuy
Postby Perrotoro » Wed Feb 27, 2019 9:29 am
Perrotoro
Postby Perrotoro » Wed Feb 27, 2019 9:52 am
Never mind - I think from RichD's linked article I have the answer - I have seen less power in curves with two or more cars on the track - and de-slotting when a car comes off. I think I'll try the $17 unit as a first try.
If I do this, I suspect I'll physically splice the output of the upgraded power supply to the electrical fitting that goes to the Carrera 30352 Control Unit - correct? Or is there another way to do this?
Perrotoro
Postby mattb » Wed Feb 27, 2019 12:30 pm
These power supplies have terminals for the plug to connect to and for the power out to connect to. One of the deals you loosen a screw and put the wire under the contact then tighten the screw. I've used one for 8 years or so. Mine is the adjustable from 9-12, I think. For our racing 12 is fine, I never run with less power. I have cars set up for newbies and kids that are slower and easier to run. My track is not hard to drive anyway.
Postby GoldGuy » Thu Feb 28, 2019 6:27 pm
Another thing about the one shown by the OP is that there are only three power out sets of terminals, the first three to the left are for power in.
GoldGuy
Postby Perrotoro » Mon Mar 04, 2019 1:52 pm
On these power supply's, how do you guard the 120v terminals from kids or dogs?
Perrotoro
Postby mattb » Mon Mar 04, 2019 2:46 pm
This is a pretty simple power supply to use if you have any experience with electric. If you don't, you should probably stick to wall warts and stock power supplies so you don't burn up your components, cars or maybe start a fire.
If this power supply is the same as the one I use, starting at left, the first 6 terminals are 3 power out negative and 3 power out positive. The last 3 terminals are the power in, pos, neg and ground. If you are concerned about people or pets getting hurt by playing with the terminals, I would just cover it with a box of some sort. This is really pretty easy to setup and use.
