A Vanquish back on the track.
Postby dge467 » Sat Feb 09, 2013 10:31 am
After a few years side lined by the rear end giving up twice, big surprise, I finally fixed it today. I used NSR gears and bushings, and a Slot It 54 mm axle. The factory rims were a little loose on the axle so I knurled the ends and super glued them on. I have to add another spacer still. I may put on some aluminum wheels. ImageIt's nice to run this one again!
Re: A Vanquish back on the track.
Postby HomeRacingWorld » Sat Feb 09, 2013 10:44 am
Nice one, so cool seeing these older cars being worked on.
Postby Dangermouse » Sat Feb 09, 2013 5:18 pm
Once you do this to them, they are really good runners, I race one in our can-am class and with an NC5 in it and it goes really well, another chap at the club has put an NC-2 in his and it goes well.
I had looked at the NSR spacers but ended up just using the ones that came with the car
David
Dangermouse
Postby FootScoot » Sat Feb 09, 2013 8:42 pm
I have one of these cars, but have never ran it. It's still NIB. I guess I need to take a look at it. :)
Postby waaytoomuchintothis » Sat Feb 09, 2013 8:57 pm
I have two and never had any trouble at all from the differentials. As soon as I got them home, I packed the diffs with the grease that the R/C guys use, and they run fantastically well. Both came out of the box with nearly empty diffs.
Postby HomeRacingWorld » Sat Feb 09, 2013 10:20 pm
It exists. It's right there.
Postby HomeRacingWorld » Sat Feb 09, 2013 10:28 pm
The off scale never bothered us much. Just raced them against each other and they were fun. Actually had a great time with them without much modding. Too bad they approached the series the way they did, it could have been a real keeper for more folks if they did them right.
Postby SOBwanhoser » Sun Feb 10, 2013 5:17 pm
BTW...I ran across this site a while back - Good article on the Vanquish differential:
http://slotmeister.com/tech.html
SOBwanhoser
Postby SpeedyNH » Wed Feb 13, 2013 6:33 pm
that's a good reference, thanks!
SpeedyNH
