Home Racing World • View topic - table sides
table sides
table sides
Postby mtrcyclu » Mon Jan 15, 2018 6:16 pm
have just about finished my 8x12 table that I am going put a track layout on. Looking for ideas for the sides of the table for something to help stop the cars from flying off the table. maybe sometype of nettting, wood boards, foamboards etc,. any ideas or pictures would be greatly appreciated. Thanks!
mtrcyclu
Re: table sides
Postby 4424ever » Mon Jan 15, 2018 6:52 pm
Use what ever is cheap and handy a couple of inches above the track surface is all you need unless the car is really flying
4424ever
Re: table sides
Postby chappyman66 » Mon Jan 15, 2018 8:01 pm
Yup, there are lots of options. 1x6, 1/8" plastic, floor cove base edging. I used gutter screen with bamboo skewers threaded through the screen. It's all about the look you want.
Re: table sides
Postby bobbyraz49 » Mon Jan 15, 2018 9:04 pm
I used gutter screen as well and am happy with the results.
bobbyraz49
Re: table sides
Postby Racer944 » Mon Jan 15, 2018 10:05 pm
I used corroplast sign making material. It's corrugated plastic so it's easy to cut, light, looks clean, and can be decorated easily. Home Depot has it amongst other places...
Cheers;
Eric
Racer944
Re: table sides
Postby mtrcyclu » Thu Jan 18, 2018 7:08 pm
Great ideas guys, thanks. How about ideas for covering the table top? Looking for something to cover the plywood top. Felt, carpet, green outdoor carpet? Thanks
mtrcyclu
Re: table sides
Postby BRS Hobbies » Thu Jan 18, 2018 7:30 pm
I like to use green outdoor carpet. You can usually find it sold by the foot or yard at Lowes.
Best regards,
Brian
BRS Hobbies
Re: table sides
Postby chappyman66 » Thu Jan 18, 2018 7:36 pm
If you are running plastic then cork or carpet will quiet things down. Indoor outdoor carpet is pretty common. I liked cork because it was easy to mount scenic items but it's all about what you like and how much space you have.
Re: table sides
Postby Aloha » Thu Jan 18, 2018 9:23 pm
Building (or should I say attempting to build) a track and have actually used rain gutters cut on a table saw for walls around the track. White in color and has a little flexibility. Sit 2 1/2" above the track surface. Just a thought for another option. Have carpet runner as well and makes everything look finished. Good luck....
Aloha
Re: table sides
Postby RichD » Fri Jan 19, 2018 6:27 am
My track has 1X4 boards around the edge, but many of our club tracks used Sintra, which is easy to bend if you want to do that. The top of my table is covered with green foam backed carpet runner, that helps to damp out the sound that the cars make as they go around the track. The runner extends up on the inside of the table boarders so it acts as padding to minimize damage to the cars.
Re: table sides
Postby chris » Sat Jan 20, 2018 4:31 pm
I use small Christmas trees that were picked up really cheap in post Christmas sales. They vary and range in height from about 10 inches to 4 inches but the common factor is they all have a twisted wire "trunk" so just a simple matter of drilling a hole and shove 'em in.
My track is about 12 x 5 so now the trees pretty much line it completely. Tried for that nostalgia look when tracks were manly and the only thing to stop the drivers going into the boonies were trees, telegraph posts or rock walls :o
Chris.
chris
Re: table sides
Postby ccobra » Sun Jan 21, 2018 11:32 am
When I first set up my Eldon track on a table with the long straightaways, I used plastic Lawn Edging stapled to the table. I used the stuff that was flat with a rounded edge on the top side. This kept the cars from flying off when the Grandkids were over. It also works well mounted to the mower to put stripes in the yard.
ccobra
Re: table sides
Postby TuscoTodd » Sun Jan 21, 2018 2:16 pm
