Sloter Lola front tire question
Postby Junior » Mon Aug 28, 2017 6:39 pm
This is probably a dumb question, but is there a good replacement tire for the fronts of a Sloter Lola? Mine have turned into brittle rocks.
Thanks
Junior
Shop Teacher
Re: Sloter Lola front tire question
Postby HomeRacingWorld » Mon Aug 28, 2017 6:55 pm
You have zero grips now :)
I think I might have some low profiles down here, I'll check sir.
Postby RichD » Thu Aug 31, 2017 10:38 am
You don't need front tires with any grip, so rocks will do until they actually fall apart. There is not much in the way of aftermarket front tires, the ones that are available are made to fit Slot.it style wheels and tend to be rather small in diameter.
