Revell-o-gram NSU TT tire help..
Postby JESIV » Tue Nov 27, 2012 5:01 pm
OK slot folks. I've searched for replacement rear tires for this car and have found nothing. Does anyone know of a source for replacement tires for the R/M NSU TT?
If not, I've considered the Ranch Design 1/43 alum wheels as a replacement but not sure on which option works and if I'll need new bushings/gears/axles too.
Again, any help is appreciated.
Thanks
James
JESIV
Re: Revell-o-gram NSU TT tire help..
Postby Rooster » Tue Nov 27, 2012 5:53 pm
These might work?
Paul's tires on his Ebay site -
2 Pair 1/32 Scale Handmade Urethane Slot Car Tires......
SOFT TIRE FOR SMOOTH WOOD and PLASTIC TRACKS.
2 pair fit Revell Trabant 601,
these tires will need to be trimmed and sanded in some cases where the axle is offset due to manufacturing tolerances... mounts at 17.9mm..... 0.5mm larger than stock tire
Rooster
Postby Rooster » Tue Nov 27, 2012 7:30 pm
I thought I saw these in the past, but I overlooked them when I went back to look and I posted previous message -
1/32 URETHANE SLOT CAR TIRES 2pr fit Revell NSU - So Paul does have them.
Rooster
Postby JESIV » Tue Nov 27, 2012 10:18 pm
Great!! Thanks a lot Rooster and Paul!!! I did the ebay search for them but for whatever reason they didn't come up in my search...I now have a direct link and a new favorite seller for future needs :banana-rock:
JESIV
