Home Racing World • View topic - New Wheels! SCC 17x8 CLASSIC STEEL!
Postby HomeRacingWorld » Fri Nov 16, 2012 2:46 pm
Re: New Wheels! SCC 17x8 CLASSIC STEEL!
Postby Scatman1 » Fri Nov 16, 2012 3:11 pm
Man, what a great Friday. First, Carrera classics, and now new wheels for my Superbird. :banana-rock:
Scatman1
Postby HRWJim » Fri Nov 16, 2012 3:14 pm
Very nice. I know what car I will do 1st. Jim
Postby Scatman1 » Fri Nov 16, 2012 4:32 pm
Harry, any chance you can gives us a time comparison between tires? Seems the like the one with the lower profile would be better.
Scatman1
Postby dreinecke » Fri Nov 16, 2012 4:50 pm
Well, hot dog! Those are the bee's knees! Really, really great work you blokes at SCC are doing!
Postby paul gage » Fri Nov 16, 2012 5:25 pm
paul gage
Postby Scatman1 » Fri Nov 16, 2012 5:51 pm
Paul, I agree with you. I was just wondering since the car has a high cg.
Scatman1
Postby HomeRacingWorld » Fri Nov 16, 2012 6:14 pm
I'll see what I can get done sir. :)
Postby Scatman1 » Sat Nov 17, 2012 10:04 am
Harry, what size axle did you use? I'm about to order a pair of wheels and would like to buy the axle at the same time. I know I have a few somewhere in all my boxe, but you can never have enough. :-)
Scatman1
Postby nhdungeonracer » Sat Nov 17, 2012 10:56 am
Tony, we always recommend upgrading to a quality axle such as Slot.It when using our wheels.
Doing some quick measuring, it appears the 48mm length would work, as would a 50mm (just to be absolutely sure)
Other quality 3/32" axles that work are Sloting +, Plafit, Parma, etc.
Postby HomeRacingWorld » Sat Nov 17, 2012 11:51 am
There you have the answer. I use 3/32nd music wire in bulk for many projects, but when I order Slot.it axles I always get the longer ones and trim them to suit the model.
Postby Scatman1 » Sat Nov 17, 2012 12:05 pm
Scatman1
Postby Scatman1 » Sat Nov 17, 2012 12:32 pm
Harry, I pulled the plug. Just ordered my wheels from SCC and tires from Paul. Can't wait to to run some laps on the new track. 4x4 Superbirds. :-)
Scatman1
Postby RazorJon » Sat Nov 17, 2012 12:38 pm
I get ejector pins, 12 inch long they are about 4.00
they are hardened and ground to a very close tolerance in straightness and diameter
Tony its the same rods that came with your jig
Postby HomeRacingWorld » Sat Nov 17, 2012 7:02 pm
Wish I had ejector pins. Must be cool to know someone who has those.
