Home Racing World • View topic - Scaley Dodge Challenger and Mercury Cougar
Re: Scaley Dodge Challenger only
Postby noddaz » Mon Apr 16, 2018 5:26 pm
I have limited experience with the Challenger, (I mean that.) but I think the answer is to find body float.
Loosen the screws a bit and fiddle with everything that interferes between the top and the bottom of the car.
Scott
noddaz
Re: Scaley Dodge Challenger and Mercury Cougar
Postby red73mustang » Fri Apr 20, 2018 9:43 am
While I'm not much of a tuner I am a big Mercury guy so I was disappointed when I did not find and 3d printed chassis for the Scalextric Cougar chassis on Shapeways. Would a 69/70 Camaro or Mustang 3D printed chassis easily adapt to the Cougar ?
red73mustang
Postby Wobble » Fri Apr 20, 2018 3:24 pm
Wobble
Postby midagekid1 » Sat Apr 21, 2018 2:04 pm
My two cents worth..I entered a Cougar in the 2017 Trans Am series and finished in the middle of the pack. I added weight in front of the motor and along the side rails. PG tires and a light weight interior. Not much else but a bit of sanding to get some body float. In my opinion it ran well. I think the problem is the length of the wheel base. With a bit more work she could have have had a better finishing position. I was the only Cougar in the field. Just my thoughts on the subject.
midagekid1
Postby Modlerbob » Mon Apr 23, 2018 5:17 pm
Remember, my situation requires that the car remains stock with the exception of replacement tires and adding weight. I think I discovered a solution for the Challenger. It's big problem has been tipping in the corners, especially on an "S" curve. I finally noticed how narrow the track is of the front wheels. I found a longer axle and added some axle spacers and got the front wheels out to just inside the wheel wells. Assuming this will be a legal modification I think I have found a way to make my Challenger competitive with the Camaros and Mustangs.
Postby chappy » Mon Apr 23, 2018 6:24 pm
I did the same as you Bob widened the track and added chassis weight, but i also loosened the body screws for a lot of float , it gave me just a bit more cornering ability as the body would rock a bit before pulling the cog in the chassis up.
They are great cars, but tuning in box stock is a tough one.
Good luck
Postby Wobble » Mon Apr 23, 2018 6:36 pm
My Challenger has a wider front axle too but I also added a Camaro rear axle to it as it is about 2mm wider. My biggest problem with the Challenger was, it was a slug and my buddies Challenger had the same problem. I wonder if ours were in the same batch and they just had weak motors. A motor change later and it goes a lot better.
Wobble
Postby Modlerbob » Mon Apr 23, 2018 10:27 pm
I'm not sure whether mine has the original motor or not. That may have been one of my earlier attempts at a fix. As it is now it has plenty of go fast down the straights but didn't corner well.
