Home Racing World • View topic - Ford-Ferrari Wars - the Cars and the Builds
Re: Ford-Ferrari Wars - the Cars and the Builds
Postby munter » Sat Sep 12, 2015 2:51 am
I did the glue and cut to a Ferrari 330 a while back.
Getting away from the clamshell idea is a plus.
This car had a broken guide mount so I wasn't too fussed if I ruined things but in reality I improved it.
I used a front section of an HRS chassis for the new guide mount and glued it in place a little further forward than before.
From memory I didn't use the six (yes six) mounting screws. I did say this was done a while back.
Postby Audi1 » Sat Sep 12, 2015 3:26 am
Hi John, Nice looking, clean job there! The grafted Slot.It guide is a nice plus on that build. Looks like you have a Ford-Ferrari Wars car all set to go......................(?) ;)
Postby munter » Sat Sep 12, 2015 2:32 pm
I cut out the lighting board and place things in individually. It also looks like I cut up the cockpit and fitted parts individually too.
Main issue is the rear rims being small and the urethanes fitted not quite gripping enough. Maybe I will work on it some more.
I would have added these pictures last night but I could not get the insert window to open...poor server at my end rather than a HRW problem I think.
Postby btaylor » Sat Sep 12, 2015 3:29 pm
Allan, this will be my second entry, and on the Ford side! Figured a J car would fit right in somewhere? :lol: I am working on it still, but so far it is a Strombecker body fitted to a Modified NSR Chassis .Early test runs show it to be a strong contender I believe.ImageImageImage
Postby Audi1 » Sat Sep 12, 2015 6:07 pm
Nice choice on the J-car, Bob! And that NSR chassis will. doubtless, be good to you.
On the black chassis, which is stiff, but not as stiff as the white chassis, I tend to lock the pod down tight, to give a little more structural rigidity to the chassis. Give it a try, if you haven't already, you can always back them off if it's slower that way.
What you're doing with those Stommie cars is great! And, I like your choice of motor................................spur looks good, too.................... :handgestures-thumbup:
Postby btaylor » Sat Sep 12, 2015 6:27 pm
Thanks Allan, Its locked down tight, I am using a three point body mount, and had to much flex till it was tightened down.
Its in the early testing stages, but its track times look very promising already.
Postby Audi1 » Sat Sep 12, 2015 7:08 pm
Postby munter » Sun Sep 13, 2015 12:56 pm
That would be a maybe.....best I can do at the moment.
When is the deadline? next year?
Postby Audi1 » Sun Sep 13, 2015 3:18 pm
Yup, the deadline is March, 31, 2016. You've got some time................~! :D
We can't have a race on The Anaconda again without a "home-town" car.............!
Postby munter » Sun Sep 13, 2015 10:09 pm
mmmmmm......I will read the rules again and see what I can come up with.
Postby Audi1 » Mon Sep 14, 2015 4:32 am
OK! :handgestures-thumbup:
Postby Audi1 » Sat Sep 26, 2015 5:26 pm
Yup, GT-40s are always fast.................!
Good luck on this one! Are we going to see a torsion bar suspension again.........................??
Postby waaytoomuchintothis » Sat Sep 26, 2015 6:12 pm
I've completely revamped what I am going to do for this one. Years ago, I did a repaint on a Coda Lunga that I never really liked. It was a sale car, damaged in shipment, and I did a David Piper green version of it, then I found out that the 512s he had weren't long tails! So, I'm fooling around with it now. I always liked the motor/axle bucket on the Fly chassis on these things, so I'm trying to use it.
Postby Retro Racer 44 » Sun Sep 27, 2015 12:25 am
Looking forward to see what you come up with for this one, Dave. I have a Slot.it GT40 body with a scratch built sidewinder chassis under it. We can compare when your done, eh?
Keith
Retro Racer 44
Postby Audi1 » Sun Sep 27, 2015 4:51 am
Return to Ford-Ferrari Wars Proxy
