33 Ford Sedan early modified finished!
Got a good start on this one so far. Building in a 60's era modified style. Small block chevy, shortened mid 50's Chevy chassis, (as many of them did around these parts) 33 ford Sedan body, wider tires, with re enforced steel wheels. I am going to build a couple of these, so I have some running mates for the little oval. These will have the Piranha motor, so as to have a little more punch than my jalopy's. Gearing will be the same at 9/31, and the tires will be wider all around for a little bit better hook up.
