1953 MG TD [FINISHED]
For 1/32nd Scale Models
Postby dge467 » Sat Oct 06, 2018 8:54 pm
This is a older reissued kit by Mini Craft of the real old Gowland and Gowland kit from the nineteen fifties. I am using a old Strombecker chassis from I believe the early 70's. It has a nice low RPM motor. I am still in the mocking up stage, the body will sit a little lower in the front. Also I am making my own wheel inserts and using the wheel center caps from the kit.
Re: 1953 MG TD
Postby btaylor » Sun Oct 07, 2018 4:15 am
That looks great. I love those old gowland kits, and the re issues. They make some fun slot cars. Looking forward to seeing your end result.
Re: 1953 MG TD
Postby Mitch58 » Sun Oct 07, 2018 5:45 am
Not too fast, but fun none the less.
Mitch58
Re: 1953 MG TD
Postby 73emgee » Sun Oct 07, 2018 6:34 am
Nice build!!!
73emgee
Re: 1953 MG TD
Postby HomeRacingWorld » Sun Oct 07, 2018 7:41 am
Yes a very interesting model. You will make a stunner as usual.
Nice one there Mitch. Not all fun slot cars are light speed fast.
Re: 1953 MG TD
Postby chappyman66 » Sun Oct 07, 2018 10:39 am
Yup, doesn't have to be fast to be fun...
That's a great build! Kitbashing allows so many more interesting cars....how about the chassis shots?
Re: 1953 MG TD
Postby dge467 » Mon Oct 08, 2018 8:33 pm
Mitch, your MG looks really nice!
I sprayed some Rustoleum Gloss Almond paint on the body. Here is also a picture of the chassis before I mounted the posts to the body. Not really a great chassis, but I am just trying to use what I have. It is [was]a brand new chassis. It dose run well though in testing! Not a real high RPM motor, but that suits this car well.
Re: 1953 MG TD
Postby Audi1 » Tue Oct 09, 2018 4:11 am
That is one nice looking car! Maybe a peak on Sunday...……….??
A lot of MG TC's, TD's and TF's ran SCCA you know...……… :lol: Just sayin'...……….
Re: 1953 MG TD
Postby dge467 » Sat Oct 13, 2018 10:51 am
After some slicing and dicing plus some scratch building, the interior is done. Driver is from Pioneer.
Re: 1953 MG TD
Postby bill from nh » Sun Oct 14, 2018 5:52 am
Nice job with the interior. It looks authentic to the car. :clap:
bill from nh
Re: 1953 MG TD
Postby Mitch58 » Sun Oct 14, 2018 8:35 am
Is that Wimbleton White? I originally painted mine that color, then switched to black, then for the "Last Open Road "proxy I added a passenger and painted it green and removed some of the parts to match the one in the book.
You've done a great job on the details
Mitch58
Re: 1953 MG TD
Postby dge467 » Sun Oct 14, 2018 2:18 pm
Thanks! I painted it with Rustoleum Gloss Almond.
Re: 1953 MG TD
Postby model murdering » Sun Oct 14, 2018 4:03 pm
Killer finish!
You know you got it right when it reflects your work bench. I see a lot of painstaking brush touch too.
I can almost read the Tach :clap:
model murdering
Re: 1953 MG TD
Postby dge467 » Sun Oct 14, 2018 9:21 pm
Well it is all done! After doing some chassis tuning as the front axle had a lot of up and down movement, so I added a piece of tubing for the axle to go through. The car was tippy through the corners before adding the tube. I also added some weight to the chassis and found some urethane tires for the rear wheels that fit well and I sanded them also. Some front tires were found in my tire pile to replace the dry rotted and out of round originals. I made the wheel inserts and the hub caps are from the craft store.I was also missing the passenger side curtain for the top, so I made one out of some plastic sheet stock. These kits come with no glass so I made my own from some clear plastic. The headlight lenses are from the junk box. The car runs really well!
Re: 1953 MG TD [FINISHED]
Postby 4424ever » Sun Oct 14, 2018 9:26 pm
Sweet ride I’m not much for English sports cars my self but that’s a nice one :music-rockout:
4424ever
Return to 1/32 Showcase
