Home Racing World • View topic - printed VW Squareback
For 1/32nd Scale Models
Postby ccobra » Sat Jun 23, 2018 2:29 pm
The other day while driving to work, I noticed a VW Squareback running down the road. So I got to thinking, found a stl. file so I downloaded loaded it. After spending about 10 hours behind the computer, I managed to model up a chassis that looked like it would fit. Then for grins and giggles I attempted to model up a Subaru engine underneath the chassis with a 4-1 exhaust.Image
Got both to print out after having some difficulty in printing them out, had to do a repair stitch and close the areas between the triangles using nettfab software. Hopefully no one will notice my goof on the body, I scaled it down to .03125 instead of .03739. Darn metrics anyway.
I got the body cleaned out with the dremel and noticed a few areas requiring a little bondo, I guess I could call it a Barn Find and it had a little rusted out body panels.
I then got the slave wheels installed so that I could see how much more work will need to be done. Looks like the CAD program was right. But after a little plasti-card, bondo, and clear epoxy it looks like after a little more sanding, it will be ready for paint.
With the body mounts glued in place its time to move on. More later after a little more sanding and some paint.
ccobra
Re: printed VW Squareback
Postby chappy » Sat Jun 23, 2018 8:46 pm
How cool is that. Man your burning the spools on this one. Looks really good so far
Postby slothead » Sat Jun 23, 2018 8:52 pm
I'm truly amazed at what you've done in a relatively short period of time. 3D printing is one of the things I've been thinking about getting into now that I'm about to retire, and this is very motivating.
I have a zillion questions which might be better addressed in a PM exchange, but for starters where did you learn how to do this and what type of computer and software are you using? I have a computer science degree (but no CAD experience) and access to a 3D lab. I'm eager to learn more so I can get started learning how to do things like this.
Slothead
Postby ccobra » Sat Jun 23, 2018 10:29 pm
ccobra
Postby ccobra » Fri Jun 29, 2018 8:03 pm
Finally got some paint to stick so hopefully this weekend will accept the one step floor shine. Then I can start with the interior work and windows.
ccobra
Postby ccobra » Sun Jul 01, 2018 8:29 am
Got the One Step laid down and the body mounted.
And now comes the hard part, getting it and myself off the track and back to the bench to finish it off. The fun is letting break in and watching the times improve with each lap. The car goes around pretty good as is with the Piranha motor and slotit gearing.
ccobra
Postby chappyman66 » Sun Jul 01, 2018 10:31 pm
I haven't figured out bodies yet. I have chassis and pods and guide flags.....but bodies are beyond me so far.
Is it as simple as taking the solid body, making an empty copy at 97% and combining the two? Hollowing out by approximate shapes and Dremel is a hard way to go.
I would love to be able to print bodies.
Postby ccobra » Mon Jul 02, 2018 3:59 pm
ccobra
Postby ccobra » Sat Jul 14, 2018 7:51 pm
I was able to work in a little bit more today. I got the side windows glued in and the interior work done.
And by the way, for those that think the 3d printer would be great for just slot cars, oh well, the little missus has had me printing out more that just slot car parts. I've done pocket door cup handles, bed post leg adapters, computer screen brackets just to name a few. Gee, she is getting into my slot car time here. :violin:
ccobra
Re: printed VW Squareback Completed
Postby ccobra » Mon Jul 16, 2018 6:12 pm
Just finished it up this evening by installing the interior, install the windows, and touched up the wheel flares. It tipped the scales at 101 grams. Now to play with it and see how it holds up with the Grandkids.
ccobra
Postby TuscoTodd » Tue Jul 17, 2018 12:09 pm
Great to see that out running around already!
Return to 1/32 Showcase
