Matra 670B Lemans 1972
For 1/32nd Scale Models
Postby VTECFOUR » Wed Mar 22, 2017 11:27 pm
Just got a seconds SRC Matra 670B Lemans 1972 body and accessories. Sure nice to get an already done body with cosmetics to cover a ready-to-go chassis , my usual adjust-o-wheelbase one.
Should be up and running in no time.
VTECFOUR
Re: Matra 670B Lemans 1972
Postby chappy » Thu Mar 23, 2017 10:02 am
Nice subject Dan, i think the Matra's are one of the most beautiful designs made.
I will be looking forward to your progress.
All the best
Postby GTI » Thu Mar 23, 2017 11:51 am
Where would you get that , I'd love to get one as well. I have the long tails and really like the short tail. Any help appreciated. Have fun with the build.
GTI
Postby VTECFOUR » Thu Mar 23, 2017 4:32 pm
@ Chappy - Hi Bob, one of my favorite Lemans cars. Being #15, the winning '72 car, made it a no-brainer purchase.
@ GTI - Got the body kit from Victory Lap Hobbies in Puyallup WA.
Body's mounted.
Rolling on Slot It 14 x 8 plastic wheels/rubber tires at the front and BRM Nascar/PG??? in back.
I'm sure it's a seconds body as there's a small fingerprint in the paint on one of the sides. Doesn't bother me.
Should be running tomorrow.
VTECFOUR
Postby GTI » Thu Mar 23, 2017 7:08 pm
Thanks for the information!
GTI
Postby VTECFOUR » Mon Mar 27, 2017 7:17 pm
All done.
Made my own interior tray using just the kit's driver head and helmet. Intake snorkel mounted on sheet plastic and glued to body. Rear wing was a snap-in. Wheel inserts are resin copies of Slot It Matra.
Chassis completed with .032 brass strip side pans soldered on to piano wire.
Not a rocket with a stock MRRC slimline motor and 9/28 gears on my little test track but feels secure and smooth. Will get a good break-in at Luf's Big Targa this Friday.
Worked out well.
VTECFOUR
Postby HomeRacingWorld » Mon Mar 27, 2017 7:31 pm
Nicely done. That body just needed some real gear under it. Mission accomplished.
Postby Audi1 » Tue Mar 28, 2017 4:27 am
Very nice! I think that the blue color is what draws me to the Matra-Simca. Will your adjustable chassis take an FC-130 motor with that car?
Postby VTECFOUR » Wed Mar 29, 2017 12:33 am
Allan,
There's quite a bit of room between the top of the slimline motor and body, so fitting a FC-130 motor with the appropriate Devised Designs motor pod in my chassis shouldn't be a problem.
I could lower the body a bit more, but would have to cut down the rear tire diameter. I like it as is.
VTECFOUR
Return to 1/32 Showcase
