HSRR McLaren 8D - hybrid chassied
For 1/32nd Scale Models
Postby VTECFOUR » Tue Oct 25, 2016 4:45 pm
Always liked the modelling effort by HSRR before Slot It's version but never ran well. Disassembled one for a good look and determined one of my hybrid chassis using Devised Designs components will work for an update.
Cut up the clamshell chassis keeping the front valence and side pods to make room for the chassis.
Body's mounted for a good stance.
Next up is trying to save as much of the original detailed interior tray and driver figure.
VTECFOUR
Re: HSRR McLaren 8D - hybrid chassied
Postby Beast Lee » Tue Oct 25, 2016 5:24 pm
Very kOoL...
HSRR built a beautiful car, even going so far to add rivet details on the bottom of the monocoque...
Another great piece of work Dan...
Beast Lee
Postby Retro Racer 44 » Tue Oct 25, 2016 5:28 pm
Hmm! I have one of those. I will put it on my to do list.
Keith
Retro Racer 44
Postby dreinecke » Tue Oct 25, 2016 9:15 pm
Great work Dan! I always liked these and had all of them until I drove a Slot.it version...yeah...
Postby VTECFOUR » Tue Oct 25, 2016 11:33 pm
Curious on the performance, so I cannabalized a FF050 motor from a Revell Monogram Porsche 904 and geared it 3:1 with a Dart Hobbies 8t pinion and SCX Pro 24t crown.
Other parts used include,
Rear wheels\tires - BRM 14 x 8 Nascar/PG 22165
Front wheels/tires - MB Slot 13 x 5/MB Slot hard tires
Guide - Sloting Plus Universal 7mm
Whoa! What a nice running car. Not as fast as my Lola T160 builds but does Slot It sub 6 second laps. Driveability's so good at 81g that I'll skip my usual brass side pans. Will do a half interior driver tray/figure to keep additional weight down.
Pleasant surprise.
VTECFOUR
Postby chrisguyw » Wed Oct 26, 2016 6:08 pm
Hi Dan, another great job!!!...on a gorgeous looking car.
Why not try a Slot-it sidewinder pod??.......the full interior will fit, and you won't be disappointed in the performance.
Chris Walker
chrisguyw
Postby VTECFOUR » Wed Oct 26, 2016 11:30 pm
Hi Chris. Yeah, a sidewinder set up would be better. That would mean a piano wire chassis. Baby steps.
In the meantime, carved out the sidepods just in case I add side pans.
Finished the modeling. Only used rear bulkhead from the original interior tray. Driver figure was cut in half to clear motor. Intake manifold separated from interior tray and glued in.
Wheel inserts from the original pressed-on aluminum wheels are too small a diameter for the rims used. Maybe the Slot It ones will work better.
Pretty much done.
VTECFOUR
Return to 1/32 Showcase
