VW Bug rat rod build
For 1/32nd Scale Models
Postby VTECFOUR » Mon Aug 01, 2016 8:37 pm
A fellow member of GVSCC threw out the idea of a VW Bug rat rod class. There's some amazing 1:1 builds out there so being inspired, I'm jumping on this.
Cut the Airfix Beetle's fenders off and mocked up some Carrera Nascar wheels with 57 Chevy front tires and Shotgun Dave rears.
Built one of my standard small car chassis using the Devised Designs super slimline motor pod.
I like where this is going with the slammed look.
VTECFOUR
Re: VW Bug rat rod build
Postby HomeRacingWorld » Mon Aug 01, 2016 8:49 pm
Now this is slammin' cool.
Postby 4424ever » Mon Aug 01, 2016 8:53 pm
Now that looks killer I love it :music-rockout:
4424ever
Postby Gameover » Mon Aug 01, 2016 8:59 pm
A smashed bug!!! Im digging it.
Postby dreinecke » Mon Aug 01, 2016 11:08 pm
Oh BABY!!! Please paint it that flat green!!!
Postby CrockettNZ » Tue Aug 02, 2016 1:41 am
sweet ride looking forward to seeing this one finished
CrockettNZ
Postby VTECFOUR » Tue Aug 02, 2016 11:55 am
Body's mounted.
Would have liked it lower but the guide's in the way.
I think a guide pivot nearer the axle would've helped.
Oh well, works for me.
VTECFOUR
Postby Lou E » Tue Aug 02, 2016 12:16 pm
I think the stance is perfect, that is going to look awesome!
Lou E
Postby VTECFOUR » Tue Aug 02, 2016 2:57 pm
Rolling chassis is my usual with a twist on the running gear.
motor pod - Devised Designs slimline motor pod
motor - Scalextric FF050 red slim can, 20K
pinion - 9t, Fly March 761 F1
crown - 27t, Fly Lotus 79
front wheels/tires - Carrera Nascar, Carrera Chev 57
rear wheels/tires - Carrera Nascar, Shotgun Dave
guide - Sloting Plus
Got a flat greyish blue in mind for the finish.
VTECFOUR
Postby Wobble » Tue Aug 02, 2016 10:35 pm
If it's a bug, squash it! ... good job.
Wobble
Postby Ky.Slot Racer » Wed Aug 03, 2016 4:33 am
Dan,
it looks pretty sweet, a very off the wall build for sure, but as cool as it gets. Chassis is clean and great fit, also. You could add a strip of styrene to the bottom of the body to fake a lower look if your not satisfied with the stance. I like it, great work !
Ky.Slot Racer
HRW Master Modeler
Postby TuscoTodd » Wed Aug 03, 2016 9:25 am
This is an AWESOME idea for a build!
Looking forward to seeing updates!
Postby MoparGreg » Fri Aug 05, 2016 7:00 am
Looks great. Its really good to something a bit different.
MoparGreg
Postby VTECFOUR » Fri Aug 05, 2016 9:40 am
Progress.
Filed and sanded down the trim but that inadvertently removed the door opening definitions as there were no impressions. So had to carefully scribe new ones. Not sure I'd remove the roofline trim again as the rear windows frames have lost something in the process.
Got some spray Tamiya TS66 Lin Gray in my supplies, so I'm thinking that'll work for a finish.
Re-mounting and glueing the Carrera Nascar plastic wheels a number of times hasn't left a really concentric fit, so the ride's a bit lumpy. Not as smooth as my other little builds but it's just for a fun class of like VW Bug rat rods.
VTECFOUR
Postby VTECFOUR » Sat Aug 06, 2016 8:30 am
Sprayed on some Tamiya Lin Gray in line with the theme. Added the detail parts - windows, dash/steering wheell, door, engine lid and hood handles. Finished off with a stick-on decal from Monogram's 55 Chevy kit.
Just need some headlamps and driver figure to complete.
Pleased with the result.
On to another build.
VTECFOUR
Return to 1/32 Showcase
