The chassis is stable and runs flat in the corners with the solid front axles and front wheels firmly planted on the track, there is no roll and the ass end kicks out pleasantly to let you know you are on the edge without losing control. The gift cards are flexible and the brass side pods stiffen the chassis as well as lower the COG.
This motor and gearing is torquey enough to lift the guide out of the slot on hard acceleration without a body on. I may fashion a brass guide weight and position that over the guide to keep the front end down. i have some old Brass N scale locomotive brass flywheels that would be perfect for this job.
