Cheetah build 2
For 1/32nd Scale Models
Cheetah build 2
Postby VTECFOUR » Fri Jun 17, 2016 11:30 am
Started on a second Cheetah beginning with a cast from my original Strombecker-bodied car.
Body's just mocked but final stance will be close.
Chassis's my usual small car one using the Devised Designs super slim line motor pod.
Will go with:
Motor - Scalextric FF050 20k red can
Pinion/crown gears - SCX Pro 9t/SCX Pro 27t
Wheels/tires - rear (Slot It F1/homemade March F1 urethanes), front (Slot It 15 x 8 plastic/Slot It low profile)
Wheel inserts - front (Slot It Ford GT40), rear (Slot It Ford GT40 turned down)
Axles - rear (SCX Pro), front (3/32 piano wire)
Curious how it'll run compared to Cheetah 1's different chassis.
Stay tuned.
VTECFOUR
Re: Cheetah build 2
Postby Retro Racer 44 » Sat Jun 18, 2016 12:24 am
Looking good Dan. Are you putting side pans on this one?
Cheers,
Keith
Retro Racer 44
Re: Cheetah build 2
Postby VTECFOUR » Sun Jun 19, 2016 6:25 pm
Body's mounted and pans installed.
Side voids to be filled with exhaust pipe detail.
Subjective running feels more planted than Cheetah build 1.
VTECFOUR
Re: Cheetah build 2
Postby Lou E » Sun Jun 19, 2016 6:34 pm
That's a great looking chassis, looking forward to seeing it finished!
Lou E
Re: Cheetah build 2
Postby VTECFOUR » Sun Jun 19, 2016 10:42 pm
Got the side pipes fabricated and soldered to the chassis side pans.
Just need the right diameter solder to insert into the 1/8" tube end to simulate small exhaust pipes.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Mon Jun 20, 2016 7:17 pm
More modeling progress. Installed GT40 wheel inserts with the rears filed down to fit the F1 rims.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Tue Jun 21, 2016 10:47 pm
Drilled, filed and sanded out window, motor manifold and grille areas. The rear window portion left was necessary as it's the body mounting post base. Works OK for me. Will just paint it black.
Getting there.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Sun Jun 26, 2016 12:37 pm
Fitted solder to simulate header detail for the side exhaust pipes.
Got the desired effect.
More modeling to go.
VTECFOUR
Re: Cheetah build 2
Postby Beast Lee » Sun Jun 26, 2016 1:25 pm
Love it...
Beast Lee
Re: Cheetah build 2
Postby VTECFOUR » Sun Jun 26, 2016 4:23 pm
Interior tray to be fitted on top of motor.
Windscreens trimmed and intake manifold, tailights and driver figure paint detailed.
Spraying Tamiya TS Metallic Forest Green for body color.
Getting closer.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Tue Jun 28, 2016 5:43 pm
Body paint's on. Tamiya fine Gray primer followed by Tamiya metallic Forest Green.
Came out as hoped.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Wed Jun 29, 2016 2:21 pm
Pretty much done except windows.
Has that Aston Martin Lemans color so I'll think about a yellow or red accent surround on the nose intake.
Good result.
VTECFOUR
Re: Cheetah build 2
Postby VTECFOUR » Thu Jun 30, 2016 11:06 am
Got the windows in (my least favorite build task) and gave the nose opening a yellow accent.
Done.
VTECFOUR
Re: Cheetah build 2
Postby TuscoTodd » Thu Jun 30, 2016 1:43 pm
That is just down right sexy!
:text-bravo:
Re: Cheetah build 2
Postby Czar » Mon Aug 08, 2016 5:46 am
I really like those exhaust pipes.
Czar
Return to 1/32 Showcase
