Aurora 32 Ford sedan hot rod
For 1/32nd Scale Models
Re: Aurora 32 Ford sedan hot rod
Postby VTECFOUR » Mon Apr 16, 2018 2:04 pm
Headers made from 1/16" solder wrapped with tape at the ends. Easy to shape into position with the desired contour.
Tuck within the frame rails nicely.
VTECFOUR
Postby Dundee Denny » Mon Apr 16, 2018 5:00 pm
Every time I jump on your updates, I don't think it can get better and it does!!
Dundee Denny
Dundee Denny
Postby VTECFOUR » Mon Apr 16, 2018 6:13 pm
Working on the rad grille/headlights now.
Cut some mesh that'll just friction fit.
I'll black out the rad and headlight support that hopefully will hide the latter.
VTECFOUR
Postby VTECFOUR » Tue Apr 17, 2018 2:34 pm
Sprayed on some Tamiya light gray primer. Just a few spots to fill with putty.
While drying, soldered on some 3/32" square brass tube at the chassis front rails to keep wayward guide wires in place.
Also, added some rear wheel insert detail with 3/32" piano wire at the hub centre.
Getting there.
VTECFOUR
Postby SuperSlab » Tue Apr 17, 2018 2:50 pm
Looking good Dan! Will we see the finished article on Friday? :D
Alwyn
SuperSlab
Postby VTECFOUR » Wed Apr 18, 2018 11:10 am
@ SuperSlab - not likely to have it done by or attending this Friday's race. Got an early Saturday start to a IPMS show in Renton, Washington. Been looking forward to this event for months.
Ended up spraying Tamiya Light Sand Metallic as it was handy.
A bit of a 10 foot job, but I'm fine with it. Some Future finish will help it shine.
VTECFOUR
Postby VTECFOUR » Thu Apr 19, 2018 12:43 am
Good progress.
Body mounted and components (engine, rad grille and headlamp buckets) in place. Paint detailed the rims and added decals
Still need headlamp lenses, driver tray/driver figure, windscreens and tail light paint detail.
Runs pretty good but it'll be a cruiser.
Quite pleased with the results.
VTECFOUR
Postby model murdering » Thu Apr 19, 2018 10:14 am
I love the play by play Dan. Thanks for taking the time to share the fun.
model murdering
Postby VTECFOUR » Fri Apr 20, 2018 7:22 pm
Some final paint details done at the front window surround and rear tailights. Made some aluminum exhaust pipes too with a little flare achieved once again with a counter sunk drill bit.
The "man" approves.
Pretty much done.
VTECFOUR
Postby Wobble » Fri Apr 20, 2018 7:52 pm
This man approves too. What a looker.
Wobble
Postby TuscoTodd » Sun Apr 22, 2018 9:07 am
That turned out SWEET!
Very cool build!
Thank you for sharing the progress shots and "how to" info on some of the steps as that is great info! :D
Return to 1/32 Showcase
