Pontiac GTO [Finished]
For 1/32nd Scale Models
Re: Pontiac GTO
Postby Broman62 » Mon Sep 17, 2018 7:39 pm
Sweeeet DG...WOW...that is spot on with the color of the original!! Got a question...obviously the color looks great on the car but how did you like the Rustoleum paint itself!! I just bought my first can of Rustoleum today to get the color I wanted (along with some trusty ‘ol Duplicolor’s) and was wondering if it went on as easy as Duplicolor does...thanks in advance!! That’s gonna look so cool when it’s done!!! :auto-layrubber: :auto-layrubber: :auto-layrubber:
Re: Pontiac GTO
Postby dge467 » Mon Sep 17, 2018 8:42 pm
Thanks again. To mount the bodies I use 1/8 Evergreen plastic tubing. I cut off a piece and screw it in the chassis and then trim it to get the desired body height. After I get my desired height, I remove it and measure it up to another piece of tubing and mark it, then cut it to the same length. After I have them all cut I screw the tubing back into the chassis. I rough up the tubing end that is going to the bottom of the body. I then rough up the bottom of the body where the tubing will sit. This helps give the epoxy some bite to the plastic. I use JB Weld Quick Weld epoxy. I add some epoxy to the post and the body and try and get them to line up well before it cures. I line it up by eyeballing the wheels in the wheel opening and lining up the guide to the center of the body in the front. And I find a center point on the rear of chassis to line up with the center point on the rear of the body. Sometimes you get lucky and it sits center in the body without any fiddling around.
I like the Rustoleum paint Browman. It just takes longer to cure because it is a enamel paint. The Testor's lacquer paint and Tamiya paint dry a lot faster. But I am in no hurry! :D
Re: Pontiac GTO
Postby bobbyraz49 » Tue Sep 18, 2018 8:20 am
Thanks.
bobbyraz49
Re: Pontiac GTO
Postby Dundee Denny » Thu Sep 20, 2018 6:14 pm
just catching up, and I want to take a big bite out of that car!
that is one of the most lush reds I have seen, great choice in color!
you won't ever lose that GTO EVER ON THE TRACK!
Dundee Denny
Dundee Denny
Re: Pontiac GTO
Postby dge467 » Tue Sep 25, 2018 5:39 pm
Thanks! The GTO is finished. I chrome foiled the trim, painted some other small details, and added some decals. I sanded the stock rubber and added a little weight. It will need some better rear tires for sure though!
Re: Pontiac GTO [Finished]
Postby Broman62 » Tue Sep 25, 2018 5:48 pm
Just gorgeous DG...that turned out fantastic :auto-layrubber: :auto-layrubber: :auto-layrubber:
Postby btaylor » Tue Sep 25, 2018 6:15 pm
That goat looks sharp! Great foil work as usual, never could master that stuff.
Postby 4424ever » Tue Sep 25, 2018 6:53 pm
Absolutely beautiful nice job :music-rockout:
4424ever
Postby bobbyraz49 » Tue Sep 25, 2018 7:13 pm
STUNNING !
bobbyraz49
Postby BRS Hobbies » Tue Sep 25, 2018 8:40 pm
Simply amazing! One of the best custom slot cars that I have ever seen.
Best regards,
Brian
BRS Hobbies
Postby Wobble » Tue Sep 25, 2018 9:41 pm
Yep, definately stunning.
Wobble
Postby proxieken » Wed Sep 26, 2018 5:10 am
Superb results. The tires and chassis seem a great match, and the detail work is first class.
proxieken
Postby HomeRacingWorld » Wed Sep 26, 2018 5:29 am
:text-yeahthat:
Just outstanding work.
Postby Fitzy » Wed Sep 26, 2018 2:41 pm
That Really Looks Great! Nice Job!
Fitzy
Postby Broman62 » Wed Sep 26, 2018 5:51 pm
:clap: :clap: Congratulations and very fitting to be the featured header pic!!! Thanks Harry!! :clap: :clap:
Return to 1/32 Showcase
