Got the chassis rolling.
Components used include:
Motor - Ninco boxer of unknown origin
Pinion/crown gears - SCX Pro 9t/SCX Pro 24t
Front wheels/tires - Slot It 15 x 8/SCX unknown origin
Rear wheels/tires - Slot It 15 x 8/ PG 22166
Guide - TSRF
Mounted chassis by sleeving the original posts with 7/32" Evergreen styrene tube, slicing them from the body and tapping them for 4-40 screws and remounting to the body at positions determined by the chassis mounting holes. Didn't have to touch the stock interior tray as it's already quite shallow.
Body stance is good keeping tire clearance in mind.
Drives smooth and planted as you would expect from a 105g car.
Turned out good.
