Chassis's running.
Parts list includes:
Motor pod - Professor Motor
Main rails - 1/8" square brass tubing, 3/32" piano wire
Guide tongue and side pans - .063 brass sheet
Guide\braid\wire - Sloting Plus, Slot It, Slot It
Motor - Scale Auto 26K S can
Pinion/Crown - SCX Pro 9t, Slot It 27t
Front rims/tires - Slot It 15 x 8, Slot It low profile
Rear rims/tires - Slot It 17 x 8, Paul Gage
Mounted body with single posts front and rear using 4-40 brass screw inserts in Evergreen 7/32" styrene tubing.
Could possibly be lowered at the front but always wary of tire rub.
Runs well with a planted feel and good spunk even at a hefty 114 grams.
