Home Racing World • View topic - 2018 NSR Nationals
2018 NSR Nationals
2018 NSR Nationals
Postby mikeinclover » Sat Jun 09, 2018 9:47 am
mikeinclover
Re: 2018 NSR Nationals
Postby Brumos RSR » Sat Jun 09, 2018 10:52 am
Take picks of em without the bodies on please
Brumos RSR
Postby Oscar Racing » Sat Jun 09, 2018 7:59 pm
Nice to see no magnets as ballast, plus plenty of time to prepare...
Very glad to see Cloverleaf hosting again...
Oscar Racing
Postby cj74 » Sun Jun 10, 2018 5:00 am
Looking forward to it! If you haven't been to Cloverleaf Racing and enjoy raciing NSR, notes the time!
Let's do this!
cj74
Postby MacMoose » Tue Jun 19, 2018 12:23 pm
MacMoose
Postby mikeinclover » Tue Jun 19, 2018 3:12 pm
mikeinclover
Postby mikeinclover » Mon Jul 30, 2018 2:36 pm
I would like to throw out a tuning tip for anyone looking for one. This is a legal tip for the Nationals that is why I have added it here. You are allowed to use NSR4855 BRASS Axle Spacers 0.160" (4.06mm) Thick for 3/32" (2.37mm) Axles in the front of your chassis to take up the slop. The spacers will slide into the hoops and should not require any modification to the chassis. It is a snug fit. You can then add some oval point set screws to your chassis and adjust the axle / front wheels to your liking.
Mike
mikeinclover
Postby mikeinclover » Mon Oct 01, 2018 9:24 am
We will be opening the doors on Friday for test and tune at 9am.
Mike
mikeinclover
Postby Fathead59 » Fri Nov 30, 2018 2:27 am
I have a question for any other type Racing , some of my builds I have been using brass washers as spacers, is there any rule against using them. My question would be for future builds for any other races
Fathead59
Postby Fathead59 » Fri Nov 30, 2018 2:30 am
And if I am in the wrong forum for that question please feel to move it to the right spot
Fathead59
Postby Pappy » Fri Nov 30, 2018 4:01 am
Fathead, only if you win is it illegal. Then you will get disqualified in the post race tech inspection. :lol: Just kidding, no rule against it in any class I race but there could be a series that requires stock spacers that aren't brass. You'll just have to check with the local slot car law enforcement organization. :D
Pappy
Postby mikeinclover » Fri Nov 30, 2018 6:51 am
For any race that we hold at this time brass spacers are legal. Most of the NSR spacers are brass anyway.
Mike
mikeinclover
Postby Fathead59 » Fri Nov 30, 2018 1:36 pm
The only reason why I ask is the spacers I have on the H&R RTR chassis are plastic and when I was building my 1/32 scale I started using the brass washers, and the reason I used them was because the bushings were brass . And by using them you were able to get the tires closer and can tuck inside the wheel wells better.
Fathead59
Return to Slot Car News!
