Quick Slicks - General Information
Forum rules
Postby Quick Slicks » Fri Oct 24, 2014 5:44 pm
There is already a fair amount of misinformation being spread about Quick Slicks - hopefully this will help set the record straight. If you have any questions, feel free to contact us directly - we'll do our best to answer any pre-sale or post-sale questions. As always, we appreciate everyone's support.
Introducing Quick Slicks
Quick Slicks are high-performance silicone tires for 1:32 slot cars. Quick Slicks offer a combination of features that have not been available in silicone slot car tire until now. Quick Slicks are an easy, affordable upgrade to improve your car’s performance.
Quick Slicks Features
Made in U.S.A.
Available to fit many popular 1:32 Euro-Style aluminum and magnesium “set screw” wheels from a wide variety of manufacturers including C.B. Design, NSR, Slot.it and Sloting+. Initially Quick Slicks are available in 27 sizes with more planned for the near future.
Quick Slicks provide excellent grip on all racing surfaces – plastic or wood (painted). The cleaner the racing surface, the better the grip.
Slip-on or Glue/true – the choice is yours. If you’re a casual racer, gluing is NOT required - you can simply slip-on a pair of Quick Slicks and start racing. If you are a more serious racer and prefer to “glue and true” your tires for maximum performance, Quick Slicks work very well with a tire adhesive such as IC2000.
If you do decide to go the glue/true route (again, strictly optional), Quick Slicks require less effort to do so than other silicone tires. Same goes for (optionally) adjusting the profile where the sidewall and contact patch meet.
Rounded outer sidewalls on all Quick Slicks give them a realistic appearance like real tires. The rounded outer sidewalls appear realistic regardless of a given tire’s outer diameter (o.d.) – no unrealistic, bulging sidewalls.
Quick Slicks designed for a specific wheel are the same width regardless of outer diameter – an important consideration when rules require tires to fit under the car body and you want to experiment with different tire diameters. With Quick Slicks, you don't have to sacrifice rear axle assembly track width as the tire OD increases.
Quick Slicks were designed and tested extensively in the real-world by actual 1:32 racers.
Quick Slicks are affordable. In fact, they typically cost $1.00 - $2.00 per pair less than other 1:32 silicone tires (our 1:24 tires are up to $4.00 per pair less). This is often an important consideration whether you race alone or participate in club/organized racing.
We offer a Quick Slicks Wheel Selector to assist you to identify which wheels fit a given Quick Slicks tire. Still not sure which Quick Slicks you need for a particular application? Give us a call (or drop us an email) and we’ll do our best to assist you.
Additional Quick Slicks Are In The Works
We’re already working hard to expand the existing Quick Slicks lineup – look for upcoming announcements as they become available.
Authorized Dealer Program
If you are a retail hobby store and would like to offer Quick Slicks to your customers, please contact us. Please note we will NOT undersell our Dealers.
:text-thankyouyellow:
Quick Slicks
Return to The Tire Shop
