Policar F1 and Podded Vintage LeMans 8 Week Series
Rules:
Policar F1 Rules
Race will be on the wood track at 11.2 volts
Stock with the following modifications allowed:
• Track width not to exceed 63mm
• Front tires may be coated with CA or nail polish
• Front track may have individual (left and right) bushings
• Any F1 style or 15 x 12 wheels may be used
• Rear tires are limited to Quick Slicks CB20, CB21, CB22, CB23, CB52 or CB53
• Guide flag may be replaced using part number SWPU/03b
• Any screw combination may be used for the body or motor pod
• Rear lower control arms on the March may be removed to help facilitate body removal
• Rear exhaust pipes may be removed to help facilitate body removal
• Rear tires may not be glued or trued to wheel
Vintage LeMans
Eligible car manufactures include Slot.It ‘Classic’ and Thunderslot
• Front axle may have individual (left and right) bushings
• Any rear tire and wheel combination is allowed as long as the rear tire width cannot exceed the width of the body when viewed from above
• Any motor is allowed up to 25K rpm
• Any gear combination is allowed
• Any guide flag is allowed as long as the flag blade does not exceed beyond the front of the car when viewed from above
• Mirrors and tailpipes are not mandatory
• Rear tires may be glued and trued to wheels
Policar F1 Rules
Vintage LeMans
