Racing at Clover Leaf Racing store
We will be starting our Saturday racing on January 27th. Doors open at Noon and we will start putting names in the computer at 1:00. We will start with 2 classes see below. We will probably run this series for 4 weeks then change the classes to something different based on input from the drivers. Rules may change if a need arises. If you have any questions or input feel to ask.
Rules:
1) Scalextric Trans Am. allowed changes Tires you are allowed to change the rear tires to Silicone tires.
2)Carrera Modern GT Allowed changes: you are allowed to change the rear tires to silicone. You can remove the reversing switch or bypass it . You can extend the braid so it is one longer instead of two braid.
Rules:
