Scalextric Trans-Am regional race
Forum for all Coverleaf Racing events.
Postby mikeinclover » Fri Apr 22, 2016 4:37 pm
Clover Leaf Racing will holding a regional race for the nationals at GT slots.
Clover Leaf Racing regional rules.
Date : May 7th, 2016. An additional race will be held after this regional race, class to be announced.
For this race, N.America finals rules will be used, except racers supply their own Piranha motors. Quick Slicks silicone tires will be handed out. You will also be allowed to use CBD wheels only 15X8 or 17X8. Race will be run on the store Carrera track. Track opens at 4:00 and racing will start around 5:00. Entry fee is $10.00.
Store address
1246 South Milford road
Highland MI 48357
Any questions related to the above please ask
Rules and general information for the nationals.
Scalextric has authorized Great Traditions (aka GTSLOTS) to run a North America race program for their Vintage TransAm series of cars. Regional races are being scheduled, culminating in a North America Final race to be held on Saturday, May 21, 2016. The Finals will take place at Great Traditions, 831 Byberry Road, Philadelphia, PA. Track opens 8 am, tech inspection starts at 10 am, racing scheduled to start about 1 pm.
To qualify for the finals, you must finish in the top 4 of one of the 2016 Scalextric Vintage TransAm regional races to be announced soon, or have a prior champion's exemption as a previous winner of a GTSLOTS championship final within the past 5 years.
All drivers that qualify and plan on attending the “National Event” should take note that the following rules will be utilized and enforced. Modifications to these rules for “Regional Events” such as the use of different tires or other specific parts or rules are permitted with advanced notification given by the race director for the event.
ELIGIBLE DRIVERS:
The top 4 finishers in each Scalextric 2016 Vintage “Trans-Am regional event held across N. America not previously qualified are eligible to complete in the N. America Championship race. All drivers that qualify and plan on attending the “National Event” should take note that the following rules will be utilized and enforced. Modifications to these rules for “Regional Events” such as the use of different tires or other specific parts or rules are permitted with advanced notification given by the race director for the event
ELIGIBLE CARS:
Only the following Scalextric Vintage Trans-am cars are permitted – ’69-’73 Camaro/’69-‘71 Mustang/’67 Mercury Cougar/’70 Dodge Challenger – all sidewinders. As they are introduced, newly released cars will be reviewed and added to the above list if eligible. See pictures below for eligible car examples:
GENERAL:
Any modifications or parts not specifically addressed in the series rules are not legal and will not be permitted. If the rules stated on this page do not indicate a part or tuning method IS allowed, it is NOT allowed. Any variations to these rules must be approved in advance by GTSLOTS.
THE BODY:
Bodies may not be modified, lightened, or cut in any way - including wheel wells, body posts, interiors, etc. EXCEPTIONS: Sharp edges, burrs, rear bearing and motor bearing support posts (mounted to the interior), and the body clearance locations for the exhaust pipes may be trimmed or sanded only to permit clearance for the proper seating of the body onto the chassis. Front spoilers may be trimmed for a minimum clearance of .040” to the track. (Note: if the front spoiler assembly is loose to the chassis and the body screws are run loose, it is suggested that the spoiler be glued in place to the chassis to prevent it from dropping and dragging on the track.) Cars must start each race with any and all front and rear spoilers/wings, bumpers, and air scoops in place as provided with the car. Mirrors and headlight covers may be missing, but should be replaced when possible. Bodies can be custom painted; however, they must have numbers on the hood and both sides as is prototypical. Bodies must be attached by any and all screws locations provided by the factory, any manufacturer’s screws may be used, and shims are permitted to adjust chassis/body tweak and height. All cars must use complete and unmodified interior w/driver figure. Interior must attach with any and all screws as designed by the factory. If body screws are run loose, tape must be placed over the holes in bottom of chassis. Windows must remain transparent.
CHASSIS:
NO TRACTION MAGNETS. Slight sanding of the edges of the chassis, including sharp edges and burrs is permitted only to allow for the necessary clearance for the proper seating of the body on to the chassis. No more than .010” of material should be removed. If a standard credit card can be passed in the gap between the body and the chassis, the sanding has exceeded tolerance and the car may fail inspection. Modifications to front or rear axle mounts is prohibited. Cars must start each race with any and all exhaust pipes in place as provided with the car.
CAR SPECIFIC ALLOWED MODIFICATIONS:
In order to foster competition and create parity between the different models of Scalextric Trans-Am cars, the following approved modifications are being permitted on a car by car basis (Note: all modifications should be made in a clean and professional manner and not deter from the proper “look” of the car):
General (all cars):
- It is permitted to swap the “non-DPR” type chassis and the “DPR” type chassis on those car types that are available with either chassis as long as no other modifications than those permitted in these rules are made.
- The DPR receptacle assembly may be removed from the DPR module plate.
- Body float is permissible, however only through the modifications and setup techniques as permitted in these rules.
Camaro (’69 – non-DPR chassis): none required at this time
Camaro (’69 – DPR chassis): none required at this time
Camaro (’70-’73): none required at this time
Challenger (’70): none required at this time
Cougar (’70): none required at this time
Mustang (’69-’71 – non-DPR chassis):
- Note: if a DPR chassis is used, the front bumper will need to be removed from either the body or the chassis as only one front bumper is required.
- The same modifications for the DPR chassis Mustang (’69-’71) as shown below are permitted.
Mustang (’69-’71 – DPR chassis):
- Note: if a non-DPR chassis is used, a front bumper will need to be installed either on the body or the chassis.
- The front wheel axle supports may be trimmed flush to the sides of the chassis to allow the front wheels to be moved closer to under the body (reduced front track). See pictures below:
- On the rear portion of the chassis in front of the rear bumper where the chassis notches (locks) in to the body, the angled portions of the chassis just in front of the ends of the rear bumper that lock the chassis to the body may be trimmed straight up and down to allow the chassis to drop into the body. See pictures below:
- The rear wheels and tires may not exceed past the body at the wheel wells by more than .050” (1.25mm) at any wheel. Spacers may be added between the chassis and the body at the rear body posts to allow the rear wheels to spin freely. A gap of .020” (.5mm) should be maintained between the surface of the tire and the wheel well fender for proper operation. If your car was originally setup using one of the larger diameter wheel/tire combinations and you switch to a smaller diameter wheel tire combination, spacers should be removed to adjust the gap between the surface of the tire and the wheel back to a gap of .020” (.5mm). See pictures below:
AXLES\BUSHINGS\WHEELS\TIRES:
Scalextric and/or Slot.it 3/32” axles and bushings are permitted. Stock or Slot.it bushings may be glued in place – no lowering. Axle shims are permitted to reduce side play in the axle assemblies. Note: the rear bushings may require the removal (or notching) of the bearing flange where it comes into contact with the motor can and will be permitted for the proper seating and alignment of the motor in the chassis assembly.
Stock Scalextric or Slot.It 15.8mm by 8.2mm plastic, aluminum, or magnesium wheels and tires are permitted on the front of the car; and Slot.It 15.8/16.5/17.3mm by 8.2mm aluminum or magnesium wheels are permitted on the rear of the car. Stock plastic wheels may be lightly sanded for the purposes of truing. Wheels may be painted. CA (Super) glue may be used to repair loose or attach plastic wheels. Front tires (stock or Slot.It) may be both glued and trued. Slot.It wheels are not require to utilize inserts, however inserts representative of the correct type for the period (usually “minilite” or “5-spoke”) are permitted.
Approved rear tires:
“Quick Slicks” # CB32, #CB33, #CB34, or #CB35 silicon tires (Note: the minimum diameter of the rear wheel/tire combination may not be smaller than .795”). All rear tires to be supplied by race host (Regional) or GTSLOTS (Regional and National) on race day unless otherwise noted. Wheels and tires should fit within wheel wells when possible, but may not exceed past the body at the wheel wells by more than .020” (0.5mm) at any wheel. No chemicals may be used on the tires. Regional hosts can determine tires to be used for their regional race. (Note: “hand out” rear tire selection subject to change due to product availability.)
GEARING:
ONLY the Slot.it 12 tooth 6.5 mm pinion and the 34/36/38 tooth (ratios – 2.83/3.00/3.17) 19 mm sidewinder spur gears are permitted. Driver may apply grease to the gears.
GUIDE BLADES/BRAID/ELECTRICAL:
Scalextric stock or Slot.It guides may be used. Any screw type or long shaft Slot.It guide may be used with a minimum amount of removal of sharp edges and burrs to allow for proper operation. If a Slot.It guide is substituted for the stock Scalextric guide then the following is permitted otherwise no other modifications to the chassis are allowed in the guide area:
Old style guide (w/spring return):
Shims will be permitted to locate the guide at the proper depth in the track slot along with additional shims to center the guide shaft in the guide support to allow for proper operation. The guide spring, spring retainer, and associated screws may be removed.
New style guide (w/removable braid plate):
Any manufactures’ braid and lead wire may be used, must be attached to the guide blade through the use of any manufactures’ eyelets or the M2 grub screw method, and may not be glued or soldered to the eyelets or braid . Wires may be held in place and supported using tape, heat shrink tubing, and/or silicone adhesive.
MOTOR:
Finals:
Only the provided handout (GTSLOTS black endbell short can also known as the Piranha 21.5k – rated 21.5k @12volts) motor is legal for the National event and will be supplied by GTSLOTS. Motors will be pre-tested and marked with an ID code; racers will provide their own pinion gears (Slot.it 12 tooth, 6.5mm); trim the motor shafts as required; and will be responsible for the proper soldering of the lead wires to the motor tabs without overheating the tabs and causing damage to the motor. No chemicals (example: Voo Doo drops, etc.) shall be added to the motors. For the sole purpose to hold the motor in place, motors may ONLY be attached in place in the chassis by using a single piece of tape supplied by the race host. Holes may be cut out of the tape to allow for cooling over the motor vent holes. Racers would receive their handout motor at a predetermined time at the event, have the opportunity to test/practice with the handout motor before the start of competition, the option to purchase a replacement motor prior to the start of competition, and keep the motor(s) at the conclusion of the event.
WEIGHT:
Weight may be added to the inside of the chassis if desired. Added weight may not be utilized to alter or limit the function or movement of the front or rear axle assemblies. NO weight may be attached to the underside of the chassis.
TRACK VOLTAGE:
Suggested 12 volts (Note: track power will be set at 12 volts for the N. America finals and the GTSLOTS regional races)
RACE PROCEDURES: (as to be used at the N. America finals and GTSLOTS regional events):
- All participating race cars will be inspected to ensure rule compliance. A few test laps (the number to be determined by the race organizer) will be allowed prior to the final inspection.
- It is the responsibility of each participant to make sure that the front spoiler, chassis, and spur gear of their car has sufficient clearance to the track and pickup rail surface so as not to rub under race conditions and will be inspected for such clearance.
- Cars will be impounded after the inspection process and drivers cannot touch their cars unless done under “green flag” race conditions under the observation of a race official.
- Any controller is permitted, provided that the controller does not store an electrical charge.
- The race director for the event (the race organizer holding the event) will have the final determination if any questions or conflicts arise.
- Drivers and/or their authorized representatives may repair broken or damaged cars (IE: damaged braids, broken wires, loose gears and/or wheels, loose or missing screws, etc.) during “green flag” conditions, only under the view of a race official assigned by the race director, repairs must be properly performed to meet all posted rules, and parts may not be torn or broken off the car where screws are used to retain the parts (IE: the front spoiler, etc.) to perform the repair.
- For any clarification of the race procedures being used at the National Championship please contact:
Robert Holt by phone (908-397-7886) or e-mail (holtr371@yahoo.com)
Bob Kuss by phone (610-996-0595) or e-mail (lotus74s6@verizon.net)
mikeinclover
Return to Cloverleaf Racing Forum
