American Thunder at Nashville SuperSpeedway
Qualifying is in the books.
Steve your #28 DNQ. The rear bearing are loose causing the body to rest on the tires. Would you like me to glue it up? Also your #88 is cocked so far to the left. Is this by design? The left side of the body is almost touching my setup block by the left rear wheel. I was shocked when I saw how much it leaned, knowing your skills.
B Taylor your #11 and Tom's #48 both are missing the right side rear screw is this by design? If so B Taylor it makes the car very twitchy but the car has good acceleration.
GameOver #3 your left wheel came off in warm up laps. Pushed back on and I couldn't pull it off so hopefully it will stay on during race. If it comes off I will add a little super glue and run your race over.
[align=left]Car # HRW User Name Qualifying Time Qualifying Position
10 Austin 1.07.38 1 Great engineering. Looks like the car to beat.
40 Arroldn 1.08.37 2 My ride. What can I say?
Blue 12 Mike 1.08.39 3 WOW appears to be all stock. What a shocker.
88 Sadco racing 1.09.43 4 Body cocked way to the left.
Pepsi 11 BTaylor 1.09.44 5 R rear screw missing is this by design?
44 Billw 1.09.45 6 Wheel hop in corners
48 locoracer Tom 1.10.48 7 R rear screw missing are you and B Taylor a Team?
21 Clem 1.10.51 8 Smooth quiet
1 Mnfordguy JR 1.10.52 9 Fast on stock tires wow.
47 HomeRacingWorld 1.11.40 10 Smooth
3 Gameover 1.11.57 11 Twitchy
83 k0z0oo1 1.11.57 12 Loud with a vibration. Surprise to me since I've seen your Forums Cup builds.
99 HomeRacingWorld 1.12.56 13 Smooth quiet and looks faster than the clock shows.
7 ShotgunDave 1.12.69 14 Smooth but a little chatter it the turns
00 hoganracing 1.13.53 15 Smooth and quiet. Stock tires???
Quaker 11 TuscoTodd 1.13.61 16 Smooth and quiet but no rear grip,loose.
52 Mnfordguy 1.13.65 17 Looks like stock tires
Zippo 12 hoganracing 1.14.71 18 Stock all screws tight no float.
31 frank9129 1.18.92 19 Slow
28 Sadco racing DNQ 20
