Home Racing World • View topic - American Thunder at Nashville SuperSpeedway
Postby arroldn » Fri May 13, 2016 7:42 pm
Qualifying is in the books.
Steve your #28 DNQ. The rear bearing are loose causing the body to rest on the tires. Would you like me to glue it up? Also your #88 is cocked so far to the left. Is this by design? The left side of the body is almost touching my setup block by the left rear wheel. I was shocked when I saw how much it leaned, knowing your skills.
B Taylor your #11 and Tom's #48 both are missing the right side rear screw is this by design? If so B Taylor it makes the car very twitchy but the car has good acceleration.
GameOver #3 your left wheel came off in warm up laps. Pushed back on and I couldn't pull it off so hopefully it will stay on during race. If it comes off I will add a little super glue and run your race over.
[align=left]Car # HRW User Name Qualifying Time Qualifying Position
10 Austin 1.07.38 1 Great engineering. Looks like the car to beat.
40 Arroldn 1.08.37 2 My ride. What can I say?
Blue 12 Mike 1.08.39 3 WOW appears to be all stock. What a shocker.
88 Sadco racing 1.09.43 4 Body cocked way to the left.
Pepsi 11 BTaylor 1.09.44 5 R rear screw missing is this by design?
44 Billw 1.09.45 6 Wheel hop in corners
48 locoracer Tom 1.10.48 7 R rear screw missing are you and B Taylor a Team?
21 Clem 1.10.51 8 Smooth quiet
1 Mnfordguy JR 1.10.52 9 Fast on stock tires wow.
47 HomeRacingWorld 1.11.40 10 Smooth
3 Gameover 1.11.57 11 Twitchy
83 k0z0oo1 1.11.57 12 Loud with a vibration. Surprise to me since I've seen your Forums Cup builds.
99 HomeRacingWorld 1.12.56 13 Smooth quiet and looks faster than the clock shows.
7 ShotgunDave 1.12.69 14 Smooth but a little chatter it the turns
00 hoganracing 1.13.53 15 Smooth and quiet. Stock tires???
Quaker 11 TuscoTodd 1.13.61 16 Smooth and quiet but no rear grip,loose.
52 Mnfordguy 1.13.65 17 Looks like stock tires
Zippo 12 hoganracing 1.14.71 18 Stock all screws tight no float.
31 frank9129 1.18.92 19 Slow
28 Sadco racing DNQ 20
arroldn
Re: American Thunder at Nashville SuperSpeedway
Postby arroldn » Fri May 13, 2016 8:09 pm
I noticed when I sorted my segment for race two it also re-sorted race 1 and oval positions. Since I don't use Excel that often maybe someone can correct overall and race 1. I'll play with it and see if I can correct it.
arroldn
Postby arroldn » Fri May 13, 2016 11:15 pm
OK fellows half the field has completed the 80 lap main event. So far your leader is Clem car #21 with a time of 4.34.42 mins fast lap of 3.36 secs. Bringing up the rear of the first 10 cars is Frank car # 31 with a time of 5.26.95 mins fast lap of 3.80 secs.
Repairs: HRW #99 lost front screw with 11 laps to go, Mike #12 glued left rear wheel on. Will run yours tomorrow. Steve #28 glued left rear wheel on. Put a spacer under the left side rear screw. This raised the body off of the tire enough to run, but it still rubs in the turns. I can get my dremel out and radius the wheel well and re-run it. Your call.
Will finish with the next 10 tomorrow.
Arrold
arroldn
Postby TuscoTodd » Sat May 14, 2016 5:13 am
Great to see these babies making laps!
Thanks for the update! :)
Postby k0z0oo1 » Sat May 14, 2016 6:37 am
I really rushed this build, and just wanted to get the Artins back on the road... It was more about the decals for me on this one. However, I don't remember it being too loud or having that big of a vibration, so may be some damage in the transmission...
Great job reporting so far!
Let's go Clem!
k0z0oo1
Postby TuscoTodd » Sat May 14, 2016 7:30 am
Qualifying data entered into the series spreadsheet: https://docs.google.com/spreadsheets/d/ ... sp=sharing
:banana-dance:
Postby arroldn » Sat May 14, 2016 8:16 am
Should have this round finished sometime tonight. Good luck to the last 10 cars which includes mine.
What's the address for the next host?
Arrold
arroldn
Postby Gameover » Sat May 14, 2016 1:01 pm
I beleive tusco is next and they finish at btaylors.
Postby k0z0oo1 » Sat May 14, 2016 1:14 pm
We were supposed to get them in NEPA at some point as well
k0z0oo1
Postby arroldn » Sat May 14, 2016 11:04 pm
Well my # 40 came in 2nd place to the #21. Both cars turned 80 laps in a time of 4.34.41 mins but he beat me with a fast lap of 3.36 secs to my 3.37 secs. If these were real cars it might have been by the space of a bumper. Closest finish I've had since I have been hosting proxies. The 3rd place car #44 was clocked at 4.36.48 with a fast lap of 3.33 secs
I will update with the full race results tomorrow.
The #44 Coast Guard car could have come in as your winner if it didn't do the bunny hop. I was surprised when I looked at the lap timer to see it was running as fast as it did bouncing all over the place. I had to glue both rear wheels on as they came off mid race which was restarted twice.
3 other cars had the left rear wheel come off. Guess in the future if we run these you may want to glue your rear wheels on.
Arrold
arroldn
Postby k0z0oo1 » Sun May 15, 2016 7:25 am
Great job holding this event, and relaying the results. Congrats to Clem, Arrold and Bill for the podium!
k0z0oo1
Postby arroldn » Sun May 15, 2016 1:02 pm
Final Results
Race 2 - Arroldn - Nashville Speedway
OK there has got to be a way to post this so the columns don't bunch the numbers all together. :?: :|
Nashville Speedway
arroldn
Postby arroldn » Sun May 15, 2016 3:41 pm
Lets see what this does
arroldn
Postby arroldn » Sun May 15, 2016 4:10 pm
OK Thanks to Todd I think I have it.
Need the Address for the next host.
Dave I know what it means to be mid-pack.
arroldn
Postby TuscoTodd » Sun May 15, 2016 5:20 pm
Arrold - glad you were able to make the results visible using that tool. :)
All - the series spreadsheet has been update here: https://docs.google.com/spreadsheets/d/ ... sp=sharing
