Modern American Muscle Car Results from Nashville
Postby arroldn » Fri Oct 09, 2015 7:30 pm
100 Laps.
Modern American Muscle Car Fun Run Nashville 100
Finish Position Car Owner & Car Number Time Fast Lap
1 Sadco Racing #22 5.25.18 FL 3.13 Fast faster fastest. Deep guide caught track joints no deslots.
2 Tusco Todd #71 5.28.30 FL 3.19 Smooth quiet. Guide snagged a couple of times on track joint.
3 Sadco Racing #10 5.44.19 FL 3.19 Fast fast faster. Deep guide caught track joints 1 deslot.
4 Arroldn #53 5.47.32 FL 3.16 Fast smooth but guide rotates to far causing fishtail where car slides to far. Will not deslot but stuck at the limit. Should have been on the podium :think:
5 Strangebrew #1 5.53.42 FL 3.35 Car has heavy front end damage. Right front wheel came off at lap 70. Hood loose and guide rubs the front clip. Right front tire rubs fender.
6 GameOver #43 6.41.71 FL 3.47 Motor was slow. First 20 laps 4.23 lap times then sped up to around 3.53. Last 20 laps slowed back down to 3.70
arroldn
Re: Modern American Muscle Car Results from Nashville
Postby TuscoTodd » Sat Oct 10, 2015 7:10 am
Arrold - the field looks right at home there! (Great pics!)
And from the looks of the fast lap times and totals it looks like they made for some good racing too! :D
Congrats SADCO Racing on taking the top step on the podium and for sharing the lower steps with my car with your other entry! (Arrold - appreciate the great run with my car! :handgestures-thumbup: )
I have updated the series spreadsheet with the latest results here: https://docs.google.com/spreadsheets/d/ ... sp=sharing
Postby strangebrew » Mon Oct 12, 2015 1:28 pm
I was going to send the NAVY car to sixtiesracer after the proxy..............
Is there enough left ???????? :roll: :oops: :cry: :cry:
strangebrew
Postby arroldn » Mon Oct 12, 2015 2:04 pm
Not sure who glued your front clip. I would say break it and see if you can put it back together. Not sure why the guide is rubbing the front clip. I think you can make it work. It needs to be extended about 2mm. This should take care of the tire rub as well.
arroldn
Postby Gameover » Mon Oct 12, 2015 2:35 pm
yep my car is toast..... thanks for running them! next up is shotgundave :)
Postby arroldn » Mon Oct 12, 2015 5:05 pm
Who is in charge and what is the next stop? ShotgunDave said he would run them but he didn't think he was in the rotation.
Cars packed and ready to go.
Arrold
arroldn
Postby Gameover » Mon Oct 12, 2015 5:45 pm
I'm in charge. He said he would a while back. If he doesn't want to run them then they will need to be sent home
Postby arroldn » Mon Oct 12, 2015 10:54 pm
Cars being sent to ShotgunDave tomorrow.
arroldn
Postby TuscoTodd » Tue Oct 13, 2015 5:21 am
Good deal! Looking forward to seeing them make another venue!
Thanks guys!
Postby arroldn » Thu Oct 15, 2015 5:20 pm
Cars are in CA.
arroldn
Postby strangebrew » Fri Oct 16, 2015 11:44 am
Do what ya' gotta'...."Stuff happens" (Jeb Bush)
strangebrew
Postby arroldn » Sun Oct 18, 2015 10:29 pm
The car was very tight in the box. I think this was part of the problem. It may have been damaged on it's trip to the first race site.
arroldn
