Home Racing World • View topic - HRW Land Speed & Drag fun run!
Re: HRW Land Speed & Drag fun run!
Postby bookie » Mon Apr 20, 2015 2:06 pm
bookie
Postby nhdungeonracer » Mon Apr 20, 2015 10:29 pm
I just noticed that in the Hot Rod class, you have me down for a 57 Chevy. It's actually a 55.
Also, for my Gasser entry, put me down for a '30 Ford.... :D
Postby TuscoTodd » Wed Apr 22, 2015 12:01 pm
Thank you for the catch on the Hot Rod class and for the added detail on the Gasser!
Changes made! :D
Postby Ky.Slot Racer » Wed May 06, 2015 6:20 am
Not much talk going on with this deal, is this still a active race ?
Myself I had yesterday planned as a test day at BULLITT SPWY. but I wasn`t far enough along on my gasser to get a real feel for it. More than anything I`m interested to find out if both cars will travel the distance in a straight line, and not bounce to much, with the 40k motors, these urethane tires are going to do some weird things. :text-yeahthat:
Ky.Slot Racer
HRW Master Modeler
Postby btaylor » Wed May 06, 2015 6:38 am
Mark, my cars are done waiting on being shipped. I have tested as much as i could, but still dont know about that top end? could need a catchers mitt for mine for all i know. :lol:
Postby TuscoTodd » Wed May 06, 2015 9:31 am
Oh this is definitely still on guys! I have just been tied up with yard work (HELLO spring time! :) ) and company from out of town to actually make headway on my builds.
I haven't tried a set of urethanes "at speed" but my bolt a set to my "Spec Drag" car to give them a whirl next week to see if they cause any issue over the foams.
The Spec Drag cars use a hotter motor than the H&R Lightning - so it should be a "worst case" type scenario. (The Spec drag cars are clearing the traps at speeds ranging from 36 - 42mph depending on how people have them geared, etc)
:D
Postby TuscoTodd » Wed May 06, 2015 11:16 am
Uh oh - Is the "Shotgun Speedworks" assembly line - home of the 24 hour scratch build - on strike? :laughing-rolling: :D
Postby Racie35 » Wed May 06, 2015 12:52 pm
Wish I knew what to build..anyone wanna send a body for a quick scratch build? I'm guessing the motor is readily available? Tire advice and weight maybe?
Racie35
Postby Racie35 » Wed May 06, 2015 1:27 pm
I've got this k&b dragster(chrome one) with really cool wheels and still soft tires but it's 1/25 I believe. Then there's the scaled down copy next to it that's more along the 1/32 lines...a copy of sorts.
Anyone have a body?
Racie35
Postby Racie35 » Wed May 06, 2015 1:28 pm
Another pic
Racie35
Postby btaylor » Wed May 06, 2015 1:44 pm
I formed some thin styrene over a 9 volt battery. it worked great for the rail body.
Postby Racie35 » Wed May 06, 2015 1:54 pm
I better break out the heat gun....Thankyou for the tips!
Racie35
Postby Ky.Slot Racer » Wed May 06, 2015 1:58 pm
Racie35,
i believe your chassis is not legal... maybe the brass one will work?
Chassis - wide open with the exception of NO factory drag chassis being allowed. Ideally we would love to see everyone try their hand at building a chassis from scratch. (great time to try your hand at fabbing one from brass, plastic, wire, wood, paper mache, etc!)
Ky.Slot Racer
HRW Master Modeler
Postby Racie35 » Wed May 06, 2015 1:59 pm
I think it is....here it is next to my revell monogram galaxie......btw ky racer...it is homemade, just patterned like the k&b.....the bigger chrome one is factory....edit, I see what you were asking now...yes the brass one is my intended chassis
Racie35
Postby Racie35 » Wed May 06, 2015 3:03 pm
Voltage these will run at? Same every track?
Racie35
