Home Racing World • View topic - 100th Anniversary of Indy proxy! Moving forward!
Re: 100th Anniversary of Indy proxy????
Postby Retro Racer 44 » Sun Sep 20, 2015 7:28 pm
No problem except the availability of 18K slim cans. The only 050 I could find in Robert Livingston's motor list between 15K and 20K was the M/T SL-2 at 18K (actually tested higher) and it is no longer produced. These motors have very low torque, but that is probably ok on an oval. Sort of like Nascar restrictor plate racing, eh?
Keith
Retro Racer 44
Postby TuscoTodd » Sun Sep 20, 2015 9:49 pm
Keith - I am using a Scaley slim can - it is factory rated at 18k.
(not sure if that helps - but they are readily available - easy to find)
Postby btaylor » Mon Sep 21, 2015 5:32 am
Guy's, The Carrera motor is readily available also, and make a brisk runner in these little cars.
http://carreraslots.com/slot-car/89562.html
And on the tire issue, the PG 21073, or 21083 will stretch over the 17x 11 insert wheel, and the outer edge of the rim can be turned down using a drill motor and a Dremel if you don't have a tire razor. Its a great look with these tires, and they can be profiled to give that Balloon tire look also, in my opinion.ImageImage
Postby TuscoTodd » Mon Sep 21, 2015 6:26 am
I like it Bob! :D
Postby Audi1 » Mon Sep 21, 2015 7:23 am
Bob, those tires look sharp on that car!
By the way, are you going to run a cream/turquoise livery on that car....................? :lol:
Postby chappy » Mon Sep 21, 2015 7:39 am
Looks good Bob.
I was sucking up resin dust with the shop vac last night.
looking forward to this proxy.
Postby btaylor » Mon Sep 21, 2015 7:42 am
Postby Audi1 » Mon Sep 21, 2015 1:28 pm
Well, the kits have arrived from our French resin body supplier. Unfortunately, they're both a little underscale; more like 1/40th scale; so they're little cars. I'll fix the Auto Union car by replacing it with a George Turner model. The Wasp will probably have to remain as it is now. It will definitely be the smallest car on the starting grid. Let's see........what to use to power a 1/40th scale, narrow body, skinny tire car? I'm thinking <10k FF-050.....,
Postby TuscoTodd » Mon Sep 21, 2015 6:26 pm
Bummer to hear that the bodies are under scale Allan - but looking forward to seeing what kind of smooth runnin' machines you can turn them into!
Postby chappy » Mon Sep 21, 2015 6:35 pm
Im glad you mentioned that Allan, also sorry it cost you to find out.
I see on the bay he advertises all his stuff as 32 scale, so good to know.
Just a thought but will an MT slimline fit on its side into the wasp.
with tire height , clearance shouldnt be an issue, and the cog in the center and
a bit higher may just be the ticket to grip on that skinny stinger.
Postby Audi1 » Mon Sep 21, 2015 8:25 pm
I was thinking the same thing this morning, Bod, as I looked the chassis over. I think a 90 degree turn on a slimline motor might just do the trick. It will have to be a front-motored/driveshaft car, though. Definitely a brass chassis......... More challenges..................
I'll get there.............I think..............
Postby Audi1 » Mon Sep 21, 2015 8:27 pm
Postby McLiams » Mon Sep 21, 2015 9:52 pm
It sits in the museum. I could go and check.
McLiams
Postby Audi1 » Tue Sep 22, 2015 4:59 am
I think I found the dimensions; indirectly. There is a very accurate 1/8 scale metal model that is 24" long, 9" wide and 7.75" high. That translates at 1/32 scale to 6" long, 2.25" wide and 1.93" high. I'll check the length measurement right now.
....clop, clop, clop (going downstairs; 2 flights)
....rummage (looking for the Wasp body)
.....hmm (measuring the body length)...........hmmm, again (re-measuring)
....clop, clop, clop (coming upstairs) :think:
Well, the body and associated parts are 4 1/2 " long; maybe up to 5" if you allow for the fact that the front wheels extend well forward past the body. But even at 4.8", that's only 1/40th sale. So, it's a small body. Perhaps I could call it the "Marmon Waspette". I'm not sure if it's buildable at that scale.............
Postby Vintage 1/24 » Tue Sep 22, 2015 6:17 am
Vintage 1/24
Mr. NY Modified
