Home Racing World • View topic - Slot Car Corner '73 IROC Proxy - Builds & Usual Chatter
Re: Slot Car Corner '73 IROC Proxy - Builds & Usual Chatter
Postby studioRS » Sat May 24, 2014 9:43 am
studioRS
Postby waaytoomuchintothis » Sat May 24, 2014 9:49 am
I actually looked around for a toy parrot to get for pictures when this happened, but I never found one worth bothering with.
Postby turbokev » Sat May 24, 2014 10:03 am
Really nice job Thompson~!
turbokev
Postby TuscoTodd » Sat May 24, 2014 10:04 am
WOW! That cooler assembly turned out looking great! :D
Postby studioRS » Sat May 24, 2014 11:00 am
I am applying the decals now.
Use the smallest of the SCC logos.
Trim the CHAMPION tight on the top and bottom.
studioRS
Postby studioRS » Sat May 24, 2014 12:48 pm
Thanks guys!
Decal update...
First time I've used these decals before. I used the MicroSOL I have and this works great. Do as the instructions say, 20 sec in hot water, then out and then 30 sec before removing from paper backing.
Soak the area with MicroSOL before applying and add a covering coat over after you dab off/squeeze smooth. Careful—the solvent will dissolve the decal clear after a few coats. I found that trying to get the decal in the right location—angle the first time is best.
studioRS
Postby studioRS » Sat May 24, 2014 12:59 pm
studioRS
Postby TuscoTodd » Sat May 24, 2014 1:48 pm
Lookin' good! I plan to start doing some work on the body of mine today! :D
Postby waaytoomuchintothis » Sat May 24, 2014 5:23 pm
Postby turbokev » Sat May 24, 2014 5:58 pm
:text-bravo:
Nice job !
turbokev
Postby TuscoTodd » Sat May 24, 2014 6:13 pm
WhooHoo! I think you may be the furthest along of any of us! Nice! :D
Postby studioRS » Sat May 24, 2014 7:14 pm
OMG Looking great! Even the motor matches the blue too.
How did you mount the body?
studioRS
Postby waaytoomuchintothis » Sat May 24, 2014 7:29 pm
The body is just resting on the tires for the shots. Its really just how I dried the Future.
Postby studioRS » Sun May 25, 2014 10:20 am
I've read a lot of how to's on applying Future, did you brush it on or use an air brush? If brushed on, does it go on thick and smooth out? Just curious, I don't have any yet, but will imagine buying a jug soon. I was planning to use my Krylon crystal clear acrylic, couple of mist coats, then thicker ones.
studioRS
Postby studioRS » Sun May 25, 2014 10:29 am
studioRS
