Home Racing World • View topic - HRW NASCAR cars have rolled into Ohio!
Re: HRW NASCAR cars have rolled into Ohio!
Postby TuscoTodd » Sat Jan 31, 2015 5:49 pm
Next up - Bibbster's #73 machine:
Postby TuscoTodd » Sat Jan 31, 2015 6:01 pm
Next up - Bibbster's Babe's #98 K-Love car:
Postby TuscoTodd » Sat Jan 31, 2015 6:09 pm
Next up - the #10 Valvoline machine of Sadco Racing:
Postby arroldn » Sat Jan 31, 2015 6:15 pm
Great pictures. Surprised to see the number of brass and brass/hybrid chassis. Delete this if it is messing up the picture flow :lol:
arroldn
Postby TuscoTodd » Sat Jan 31, 2015 6:16 pm
Next up is Audi1's #19 Yellow machine:
Postby TuscoTodd » Sat Jan 31, 2015 6:19 pm
Postby TuscoTodd » Sat Jan 31, 2015 6:32 pm
One last bit of "technical" data to add to the pictures...
Below is a table showing the front / rear / total weights and the associated front/rear bias for each car - definitely an interesting spread! :)
Enjoy!
Postby Slot Therapist » Sat Jan 31, 2015 8:12 pm
Wow. I was definitely impressed with the entire field. So fast and so fun.
Slot Therapist
Postby Audi1 » Sat Jan 31, 2015 8:46 pm
Great report, tech pics and weight stats, Todd. Thanks!
Looks like I'm the only car without some weight in the front.................jibes with what you wrote into you driving impressions earlier. I can fix that! .....................next year.........
Postby arroldn » Sun Feb 01, 2015 6:44 am
Allen,
Its interesting that the weight balance of your car #19 and my #17 are almost the same but my car performed much different on most of all the tracks. I'm not sure if its gear ratio or what that's causing your car to be so quick yet so far on the edge. I do recall you car had much more free rolling resistance than any other car in the field. This may have caused us to not be braking early enough going into the turns. Put some weight in the nose and see if it still turns similar lap times or even faster because you can now brake later.
Arrold
arroldn
Postby Audi1 » Sun Feb 01, 2015 7:56 am
Yup, that sounds like the right recipe to me, Arrold. Your #17 and my #19 are very similar builds; except for the weight in the front. I'll give it a try.
Way too many offs the way that it's driving now...........except on Steve's track. Let's see what happens on the 8-lane banked oval..............
Postby TuscoTodd » Sun Feb 01, 2015 9:39 am
Allan -
I think a little front weight would make a huge difference in your car as it was one of the fastest both off the line and down the straights - but unless you made it a point to "roll" into the power easily, it would actually jerk the front end up hard enough to pull the guide right out of the slot!
Definitely a rocket ship in the making!
It will be interesting to see if the banked curves of the oval negate that effect this next week and send her screaming to the front. :)
Postby Audi1 » Sun Feb 01, 2015 10:35 am
Let's see.........what do I have left to cross.......fingers, toes,......... :lol:
Postby arroldn » Sun Feb 01, 2015 12:50 pm
Dave you will find that same thing in the VNFR. A good mix of plastic and brass on the podium.
arroldn
Postby TuscoTodd » Sat Feb 07, 2015 3:04 pm
