Home Racing World • View topic - HRW Land Speed & Drag fun run!
Re: HRW Land Speed & Drag fun run!
Postby Racie35 » Sat May 09, 2015 6:57 pm
One more pic to show scale
Racie35
Postby TuscoTodd » Sun May 10, 2015 5:28 am
Definitely liking the looks of the new build! Looking forward to the updates as you progress! :handgestures-thumbup:
Postby Racie35 » Sun May 10, 2015 5:55 am
I'll do more today. What I should do is get a chassis jig. I'm getting burned too much!,gotta stop holding things.
Looking for a set of 1/32 dragster type front wheels and tires if anybody has a stash.
Racie35
Postby TuscoTodd » Sun May 10, 2015 7:51 am
Racie35 -
Not sure what others are doing for sourcing theirs - but I plan to use a set from a National Motor Museum 1/32 die cast like the ones shown on the car in this link: http://www.ebay.com/itm/National-Motor- ... 2ee12ffa3e
Figure that is probably the closest I was going to be able to find in a skinny, scale looking wire wheel. :)
Hope that helps!
Postby Racie35 » Sun May 10, 2015 8:02 am
Thanks Todd...I was just on ebay looking at those extra hands vise thingies and ceramic soldering boards. Those wheels look the part for sure...I know I've seen finger bikes with nice wheels before. I may check them too.
Racie35
Postby Racie35 » Sun May 10, 2015 12:22 pm
Here it is...all sized down to HR motor size...hope you like
Racie35
Postby Racie35 » Sun May 10, 2015 12:23 pm
One more pic
Racie35
Postby TuscoTodd » Sun May 10, 2015 1:41 pm
That looks pretty darn sweet!
:text-bravo:
Postby Racie35 » Sun May 10, 2015 2:22 pm
Thankyou....now that I got goofy and installed 3/32 bushings I gotta find different wheels..not feeling too bright right now.
But otherwise I like the narrower chassis and the little bit of length. My motors are ordered so hopefully I can test it soon....I'd install a mount to fit this motor if I were certain they're the same.
Racie35
Postby TuscoTodd » Sun May 10, 2015 3:15 pm
The Lightning II is a FK130 - which is "similar" - but does not have a plastic endbell like the lower rpm motors from H&R.
Here is a shot of what the Lightning II looks like:
And a shot of it installed in a chassis:
Hope that helps! :)
Postby Racie35 » Sun May 10, 2015 3:39 pm
Yes it does...I can just make a mount for this and swap out the motor when it comes in. I wanna do wheelies!
Racie35
Postby TuscoTodd » Sun May 10, 2015 6:31 pm
Postby TuscoTodd » Mon May 11, 2015 6:14 am
Postby Racie35 » Mon May 11, 2015 1:41 pm
Dave....depending on what older drag cars you have....I'll bet one could be narrowed easy enough if it's brass, then set to length for 1/32. Then all you need is to mount the motor and parts.
Racie35
Postby Racie35 » Mon May 11, 2015 2:25 pm
Gabbed up a body...I'm getting there.
Racie35
