SCC Gear/Wheel Reamer
Re: SCC Gear/Wheel Reamer
Postby HRWJim » Sat Jan 25, 2014 5:38 pm
Agreed great tool. JIm
Postby FootScoot » Sun Jan 26, 2014 7:14 am
It will also work on bushings that aren't quite aligned. Another handy size is a 2mm one for use on pinion gears, as I solder mine on, less risk of bending a motor shaft. :)
Postby munter » Sun Jan 26, 2014 12:05 pm
A reamer is a good tool to have in the toolchest.
I went to an engineering supplies shop and paid a fortune for one.
They work well as you say on NSR rims but also on the cheapest alloy rims here in NZ......MRRC
Footscoot, I hadn't thought of a 2mm one...might investigate that further, thanks
Postby ddyke » Thu Jan 30, 2014 3:42 pm
Are they solid carbide, cobalt or HSS?
ddyke
Postby Ember » Thu Jan 30, 2014 4:17 pm
I only know one needs to be careful of rust. :( But it's a useful little critter.
Postby SlotCarCorner » Tue Feb 04, 2014 12:04 am
The reamers we offer are high-quality HSS - with reasonable care, they will last many years reaming "soft" aluminum wheels and brass/aluminum gears.
SlotCarCorner
