by Abarth Mike » Sat May 04, 2013 12:07 am
Used to do similar in Karts even though they have self aligning bearings, Install the axle. loosen on bearing. Wobble the axle around until the end on the axle aligned with the opposite bearing, then tighten. Repeat for the other side.
Did it do any good, who knows but as has been said it is an accumulation of the details.
