Home Racing World • View topic - Brake wiring
Brake wiring
Brake wiring
Postby indybob007 » Sun Nov 15, 2015 12:17 pm
Can someone tell why in all Wiring diagrams of slor cars' It show the negative wire going to the middle post 'the brake post that is' then to the track. It seems to me you can just run all the negatives to the negative sides of the track' then just run a wire from the brake post to your negative block juntion. It will cause a short the same and make the brakes work. Seems it is easier that way. Thanks for any help. Indybob
indybob007
Re: Brake wiring
Postby Nor Cal Mike » Sun Nov 15, 2015 1:24 pm
Re: Brake wiring
Postby TsgtRet » Sun Nov 15, 2015 4:11 pm
At the track where I race the Red is in the middle but there is enough space so the clips can't touch.
Re: Brake wiring
Postby SlotCarCorner » Sun Nov 15, 2015 10:04 pm
SlotCarCorner
Re: Brake wiring
Postby indybob007 » Wed Nov 18, 2015 6:22 am
Thanks guys for all the info. Indybob
indybob007
