Home Racing World • View topic - Oddball SCC part
Oddball SCC part
Oddball SCC part
Postby Modlerbob » Tue May 01, 2018 10:18 pm
Last week I ordered a 16K FC130 motor from SCC to install in my Scaley Caterham 7. The original motor seemed to me to be a bit too hot for that size car. As this slot car has a front mounted motor it is difficult to remove and replace it due to the spring used as a coupler to connect the drive shafts. As usual I ruined the spring getting the motor free. I found a ball point pen ink tube and cut it to size only to find out the inside diameter was just a tad to large causing slippage between the motor shaft and the drive shaft. So I looked around my bench and spotted a SCC ball point pen. After removing the ink tube I discovered the diameter was perfect making a very snug fit. So my friends, if you ever need a new coupler for a front mounted motor, remember the ink tube from a SCC ball point pen will do the job perfectly.
Re: Oddball SCC part
Postby Rleog » Wed May 02, 2018 6:39 am
Bob,
You've inadvertently discovered the clandestine method that SCC uses to deliver top secret parts to select customers, mostly members of their factory racing teams. Somehow the drive shaft coupler delivery device got into your hands and you uncovered it.
Good sleuthing!
Rleog
Postby Half Fast Slotter » Wed May 02, 2018 7:01 am
Wonderful, that is karma coming back to thank you for one of the many good deeds you have done. You could write karma a thank you note. Ah, if only you still had a working pen in the house.
Half Fast Slotter
Postby Pappy » Wed May 02, 2018 7:02 am
Pappy
Postby SlotCarCorner » Wed May 02, 2018 12:07 pm
:text-goodpost:
The moral of the story, make sure there's an SCC pen on your workbench.
:D
SlotCarCorner
Postby tjettom » Wed May 02, 2018 1:23 pm
You mean to tell me Slot Car Corner has ink pens too? I must take a quick inventory... I suddenly feel the need for a new order....Ink pens huh? Now were talkin! ...gotta get me one!!!
Regards,
Tom Baker
tjettom
Postby Changing-Gearz » Wed May 02, 2018 1:38 pm
You know that Dum-Dum stick doubles as fine corner sander right? I thought that was common knowledge - but maybe it's secret...
Changing-Gearz
Postby waaytoomuchintothis » Wed May 02, 2018 3:40 pm
Gearz, you break me up! Actually, I have used a metal dowel that small to get inside fretsaw cuts! Yes, I hated it.
Meanwhile, Bob! Look what you did! That's a great tip. I have been using a metal tube over the thin motor shaft and silver soldering it in place like sweating a water pipe. It doesn't come up all that often, but avoiding that PIA even once calls for my gratitude.
SCC guys- From now on, I want pens instead of Dum-Dums, Ding-Dongs, Clown Kakes, or even Christian's autograph!
Postby Fathead59 » Fri Sep 28, 2018 4:22 pm
I looked all over the SCC web sight, doesn't look like the have the pens in stock , I wonder if you can back order them ?
Fathead59
Postby beslotted » Fri Sep 28, 2018 6:18 pm
beslotted
Postby SlotCarCorner » Sat Sep 29, 2018 12:44 pm
SlotCarCorner
