Home Racing World • View topic - Bristol Raceway
Bristol Raceway
SHOW YOUR SLOT CAR TRACK!
Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 10:57 am
slotcar7
Re: Bristol Raceway
Postby HomeRacingWorld » Tue Jan 28, 2014 11:02 am
Pretty nice setup, having it easily changed is a great option.
Thanks for sharing.
Re: Bristol Raceway
Postby dreinecke » Tue Jan 28, 2014 11:03 am
I like the modular idea. Very clean track!
Re: Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 11:17 am
Thanks, the one thing I did different on this track is the white plastic walls in the corners are attached to the solid red walls in only three paces so there is some give when the cars deslot and hit the white walls. Saves a lot of damage to the cars.
slotcar7
Re: Bristol Raceway
Postby Wolseley Hornet » Tue Jan 28, 2014 11:35 am
Beautifully neat and tidy set up.
Do you have a big group of regular racers?
David.
Wolseley Hornet
Re: Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 11:43 am
Rarely do I have the slot car guys over. I mainly use it to tune my own cars.
slotcar7
Re: Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 2:38 pm
I'm 30 minutes from Detroit in Livonia Mich. Professor Motor's is also located in Livonia. If you're not familiar with the Professor he has 4 1/32 tracks at his store plus an incredible selection of 1/32 stuff.
slotcar7
Re: Bristol Raceway
Postby waaytoomuchintothis » Tue Jan 28, 2014 2:40 pm
Or I would have guessed extreme western Virginia?
Livonia, eh? I have some friends who go there to see Andy from time to time.
Really good job. How did you set up the alignment for the sections? I have seen some that were really clever, and I'm curious about yours, which look nearly seamless.
Re: Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 3:27 pm
Andy does have a nice place. To set up the alignment I just routered the first section attached the next section and worked off the first one. To attached the sections I used a 4'x4" board under the two sections and shimmied the sections with thick paper to get them even.
slotcar7
Re: Bristol Raceway
Postby slotcar7 » Tue Jan 28, 2014 6:16 pm
I didn't name the track after the famous raceway I actually live on Bristol street.
slotcar7
Re: Bristol Raceway
Postby TuscoTodd » Tue Jan 28, 2014 6:32 pm
5/8" solid black plastic? That sounds like it would make for a nice stable track!
Looks great and love the modular effect!
Re: Bristol Raceway
Postby slotcar7 » Wed Jan 29, 2014 10:40 am
Three of the sections I used 5/8" solid black plastic (this material is normally used for outdoor signs) the material cut and routered the same as MDF and the advantage is it doesn't have to be painted but the big disadvantage is the cost of a 4x8' sheet is $125. MDF is about $20.
slotcar7
Return to Reader's Roads
